How do you save pics and stuff on the droid maxx? If there is no SD card...
What do you mean by save? They are saved to the internal memory. Are you trying to get them off the phone and onto a new phone or computer?
Cause you have multiple cloud services to pick from to sync your photos and data to. Most cost money, but they exist.
You can plug external storage into the micro usb port. I've had no problem using an SD card reader via usb, a flash drive, or portable hard drive as long as they are the right file format.
Bluetooth and Wi-Fi direct can move them to another phone.
Plugging the phone into a computer would allow you to move data.
There are plenty of options.
