Busted51
when your "in call" you can press the volume up button and it'll increase the volume of the call..
I have no problems with mine
Posted via my awesome, longer lasting phone than yours aka droid MAXX
this may be a shot in the dark, but when you notice the volume problems, are you guys by any chance on headphones or bluetooth? just finding out that there's some volume reducing feature in android 4.2 to protect hearing. here's the thread, the info is on the last page towards the bottom http://forums.androidcentral.com/google-nexus-4/229041-how-do-i-disable-unsafe-volume-warning.html
Thanks for the info. I have not personally tried using headphones. The low volume I've experienced has been purely at the earpiece. I will give headphones a shot.
Oh and fwiw, speaker phone is nice and loud, but some conversations aren't for public consumption lol
Sent from my Nexus 7 using AC Forums mobile app
I was going to chime in and say I think the volume is excellent. I've got a bit of hearing loss and I had a very hard time hearing conversations on my S3. Every conversation I've had on my maxx has been great, clear and easy to hear.
My experience in general. The volume is decent on most calls and a bit lower on a few. I find myself checking the volume level during some calls. The volume could afford to be a bit louder, or like Samsung has implemented, a method to boost volume in call.Agreed the highest setting is fine, but in the event I was somewhere loud it would not cut it.
I have been using mine since launch and have had no earpiece issues. In fact, at top volume it is quite loud. The sweetspot of the earpiece is kind of small though, so you may have to adjust how you are holding it.
Sent from my XT1080 using Tapatalk 2
Tested the Maxx in store and the volume was fine. Bought 2 Maxxes for my house and the volume is fine. I can hear the caller. But the volume does seem to be slightly lower than what I'm used to in comparable handsets. But far from a deal breaker.I have the Droid Mini, and my brother has the Maxx. Great phones, other than you cant HEAR someone on the other line on a normal call. Bluetooth calls are perfect. Phone is great in every way but I need to be able to hear someone speaking to me on a normal call. This is likely a problem on the Droid Mini, Maxx and Ultra.
Very very disappointing, hopefully a software fix will come soon if no one is aware at Motorola/Google yet.
