1. anon(661246)'s Avatar
    It just seems to use at least 5% of battery usage?
    08-31-2013 06:40 PM
  2. josiahlikesminecraft's Avatar
    It helps if you use it right.
    08-31-2013 06:57 PM
  3. Dreamliner330's Avatar
    A lot of battery programs function by disabling data, only turning it on at scheduled intervals or screen wake up. You'd be better off installing the Snapdragon BatteryGuru app.
    08-31-2013 06:58 PM
  4. Optimus Prune's Avatar
    It definitely works. But it accomplishes the battery savings by shutting down systems while you're not using them. The more that's shut down, the more savings. Like those active notifications? Well, if you have JD set aggressively, you won't get any, because JD will shut off data while you're not using the phone. All of the systems need time to turn back on once you start using the phone again, of course, so it introduces some delay. It works, but overall, I found it to be not worth the inconvenience. And that was before I bought a phone that lasts 28 hours on heavy use.
    Sent from my XT1080 using Tapatalk 4
    08-31-2013 08:18 PM
  1. Any good roms?
    By wickedninja667 in forum General Help and How To
    Last Post: 04-13-2015, 09:25 AM
  2. Why did they do this?
    By neonworm in forum Samsung Galaxy S3
    Last Post: 09-01-2013, 03:38 PM
  3. How do you take a screenshot?
    By Travisimo in forum Moto X
    Last Post: 08-31-2013, 05:46 PM
  4. Viewing Images without stretching to full screen
    By dacop in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 08-31-2013, 05:40 PM
