1. RivertonPaul's Avatar
    I have lost the ability to control my volume levels. I cannot change the volume and cannot toggle between silent, vibration and volume on. Any magic fix?
    09-16-2013 07:56 PM
  2. Eclipse2K's Avatar
    Reboot your phone.
    Sent from my Motorola Droid Maxx using Tapatalk 4
    09-16-2013 08:24 PM
  3. RivertonPaul's Avatar
    Thanks, I have rebooted, wiped the partition cache, etc. Still no luck.
    09-16-2013 08:33 PM
  4. Eclipse2K's Avatar
    If you hold the power button down can you choose the volume as sound or vibrate from there?
    09-16-2013 08:38 PM
  5. RivertonPaul's Avatar
    Holding the power button brings up the volume options, but doesn't accept any input (the volume stays the same and it will not toggle).
    09-16-2013 08:41 PM
  6. RivertonPaul's Avatar
    The problem seems to have been the Audio Manager app. I have been deleting apps and unpairing bluetooth devices. Finally seems to have resolved with that uninstall. Thanks for the suggestions.
    09-16-2013 08:48 PM
  7. trucksmoveamerica#AC's Avatar
    I have found anything that tries to control volumes, sounds mess the phone up. Debating about sending the phone back and going back to the s4 out tri the LG g2
    Sent from my XT1080 using Tapatalk 4
    09-16-2013 11:04 PM
  8. Eclipse2K's Avatar
    That was going to be my next guess. While having so many apps at our disposal is great we also can run into bugs.
    09-16-2013 11:29 PM
  1. Replies: 5
    Last Post: 10-01-2013, 02:48 PM
  2. Received updated version of Poetic SlimLine case in the mail?
    By CharlieK581 in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-24-2013, 11:35 AM
  3. Mic volume too low on VOIP calls
    By EverNap in forum HTC One M7
    Last Post: 09-16-2013, 11:07 PM
  4. Volume issue
    By JRLiger in forum Motorola Droid MAXX
    Last Post: 09-16-2013, 04:36 PM
