1. elel13's Avatar
    I'm one of the many users who switched from the galaxy nexus to the maxx. Switched three days ago, and what a huge difference! Phone lasts for days vs having to recharge my nexus 2-3x a day.
    That said, the volume seems to be way too low. Works ok with Bluetooth on my car, but on the earpiece or when using a plantronics Bluetooth headset, I could barely hear anything when I was outside or on the train. It was noticeably worse than my nexus. I kept cranking the volume higher with no impact. Any suggestions?
    09-18-2013 09:09 PM
  2. SeigaGen's Avatar
    Greetings,
    You will want to check the sound settings. Make sure all settings are high and then run tests to tweak by lowering settings. It should get fairly loud!
    Sent from my XT1080 using Tapatalk 4
    09-18-2013 09:34 PM
  3. elel13's Avatar
    Interesting...I turned on audio effects and it seems to be better. Could it be that easy?
    09-19-2013 07:09 PM
  1. Contacts slow to appear on my Samsung Galaxy s4 mini
    By selimlok in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-20-2015, 01:28 PM
  2. T-mobile network issues.
    By anthony2558 in forum T-Mobile
    Last Post: 09-25-2013, 11:36 AM
  3. Is there a way to automatically update apps?
    By lachdanan in forum HTC One M7
    Last Post: 09-21-2013, 07:26 PM
  4. Non Essential Apps On Android. Which To Remove?
    By needspractice in forum The Android Central Lounge
    Last Post: 09-21-2013, 04:20 PM
  5. Replies: 2
    Last Post: 09-19-2013, 07:55 AM
