1. ulnek's Avatar
    does it harm the battery if i leave it plugged after fully charged? i usually leave it plugged in overnight while i sleep. i hope that's not going to ruin the battery. plus i want to plug it in at night even if i have plenty of juice left just to get it back to 100% by morning.
    10-20-2013 07:38 AM
  2. Einsteindks's Avatar
    Its a lithium battery so it pretty much doesn't matter. It most likely goes into some sort of trickle charge mode at the end when its fully charged. The only real caveat I've only found is that going below 15 percent should be avoided if possible. Running it down there about once a month should be just fine but be sure to charge it up to full directly after.
    fat-fingered and Maxx-ed out.
    CR6 likes this.
    10-20-2013 07:46 AM
  3. ulnek's Avatar
    why what does that do? i sometimes get my original razr maxx down to below 10%. that's not good to do?
    10-20-2013 07:56 AM
  4. Einsteindks's Avatar
    Some sort of technical chemical mumbo jumbo about the characteristics of a lithium battery, which I don't remember, let alone fully understand. Its not a hardcore, set in stone, cut and dry type of rule but just a general guideline. I'm guilty of it too, but I try to avoid it when I can.
    10-20-2013 08:02 AM
  5. Adamsberg's Avatar
    Li-Ion batteries have an embedded protection circuit against overcharging .... and against deep discharging so their cells should never go down to 0%.
    Though I'd not risk it to run my phone down to 0%
    10-20-2013 08:32 AM
  6. ulnek's Avatar
    lol ok. good thing to keep in mind, though i doubt the maxx will get down to that when i get it.
    10-20-2013 08:38 AM
  7. Masheen's Avatar
    I've always had the compulsion to take my phone off the charger shortly after hitting 100%. I've stopped overnight charging, but I'd still like to know if it is harmful to the battery if the phone is left connected to a charger after hitting 100%.
    10-21-2013 03:16 PM
  8. Adamsberg's Avatar
    Install a battery monitor app like 'Battery Monitor Widget' and let it show you what happens after hitting 100% ... at a log or at a graph.
    There isn't any amperage flowing, meaning, there isn't any charging.
    Masheen likes this.
    10-21-2013 03:40 PM
  1. note 2 battery question
    By ska916jedi in forum AT&T Galaxy Note 2
    Last Post: 04-22-2014, 12:18 AM
  2. Samsung Galaxy Note 3 - Battery says it's charged, but it's not.
    By ZarathustraHead in forum Samsung Galaxy Note 3
    Last Post: 01-18-2014, 09:21 PM
  3. Best Extended Battery?
    By DRILLINDK in forum Samsung Galaxy Note 3
    Last Post: 10-21-2013, 12:09 AM
  4. How do I know if my battery has been inflated?
    By kurdtcobain1990 in forum Samsung Galaxy S4
    Last Post: 10-19-2013, 11:49 PM
  5. Samsung Galaxy S4 - Tasker question: How to read/write the external SD card?
    By BillDennes in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 10-19-2013, 05:08 PM
