1. Xensity's Avatar
    I downloaded and installed the latest Jellybean update over WiFi two days ago. My MAXX has been restarting constantly ever since. It will boot into the BootMode screen (when I hold down power + vol down) but neither recovery nor factory reset triggers anything different, just a normal start-up followed by infinite restarts. Draining the battery and charging also didn't help.
    I need my phone tomorrow for my job--any suggestions on how to get this fixed? Is there any way to flash a clean OS install over USB?
    I'll stay active and answer any more questions if the information here wasn't enough. Thanks in advance for the help.
    11-10-2013 04:55 PM
  2. CrazyRussian007's Avatar
    Was your phone rooted?
    11-10-2013 05:08 PM
  3. Xensity's Avatar
    It shouldn't have been, unless the person holding on to it on Friday did so and hasn't told me. Any way to check in the 5 seconds between boots? And what does that mean about my ability to fix this?
    11-10-2013 05:14 PM
  4. CrazyRussian007's Avatar
    What Jellybeans update did you download and from where?
    11-10-2013 05:23 PM
  5. Xensity's Avatar
    It was 4.2.something, don't remember exactly. It downloaded directly over WiFi so I assumed it would be solid. The stock OS downloaded it automatically and told me to install.
    11-10-2013 05:26 PM
  6. CrazyRussian007's Avatar
    Well, try House of Moto tools to reset to factory saving data and the try updating again
    11-10-2013 05:32 PM
  7. Xensity's Avatar
    Worked! Thanks for the suggestion.
    11-10-2013 06:54 PM
  1. Assistive Light Does Not Work. Pls help.
    By SPociask in forum Samsung Galaxy S4
    Last Post: 11-28-2014, 12:41 PM
  2. Random reboots since update
    By Spacemaker24 in forum Verizon Samsung Galaxy Note 3
    Last Post: 04-01-2014, 09:35 AM
  3. Replies: 6
    Last Post: 11-10-2013, 06:13 PM
  4. GMAIL and Hangout Unread Count in Shortcut bar?
    By Jonathan Haber in forum Google Nexus 5
    Last Post: 11-10-2013, 03:54 PM
  5. Phone is different after factory reset
    By Jibbyc in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-10-2013, 03:28 PM
