For those that are pondering the switch I'd like to start a thread so people can see which apps work and don't work (or kind of work). I'll try to update this thread when others post issues.
Updated: 14JAN2014
Launchers:
Apex Launcher: Pushing home key acts like a double tap. Disable the home key action to fix it.
Nova Launcher: Pushing home key acts like a double tap. Disable the home key action to fix it. (skatergirl)
Apps
Chomp SMS: Can send txts with it, but it wont show the txt i sent or the txt responses I get back (Billy Sweeney)
EasyTether: See FoxFi.
Fancy Widgets: Selecting the forecast on the widget opens the full weather app but now it's overlaying my default screen. Also, pressing the hour on the clock no longer opens the alarm app. (Lyle J)
FoxFi: No more wifi tethering. They say that it will not work with Kit Kat. This may change in the future if they figure out a way to make it work. You must use bluetooth or USB tethering.
Go SMS: showing my sent texts twice, but recipient correctly gets only one (pappy53)
GSam Battery Monitor: Doesn't Work (pappy53)
Hancent: Can send txts with it, but it wont show the txt i sent or the txt responses I get back. Double sends texts.(skatergirl) UPDATE: App updated
Rainy Days: Double tap zoom doesn't work (lmdroid)
Updated: 14JAN2014
Launchers:
Apps
