05-05-2018 12:19 AM
57 123
tools
  1. Ernest Adu Mensah's Avatar
    It worked on me thankyou very much God bless you x
    where can i found the Tiny flashlight app is it the same as Trusted Device
    01-18-2017 09:52 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! No, Trusted Devices is related to Smart Lock, which is an Android feature. Tiny Flashlight is an app that you would have installed. Look for it in the Settings>Apps​ menu.
    01-18-2017 10:18 AM
  3. Jayceeee kk's Avatar
    How do you remove the flashlight app?
    04-01-2017 12:41 AM
  4. doogald's Avatar
    This is a forum for the Motorola Droid Maxx, which does not come with a flashlight app - so, you have to install your own flashlight app. You remove it the same way that you'd remove any app that you installed from the Play Store (or installed from another source.)
    At this point, though, this issue is a few years old. I'm not sure that this is the cause of issues with WiFi/Bluetooth anymore?
    04-01-2017 05:57 AM
  5. Carissa Minissale's Avatar
    I'm actually still having this issue.... Android 4.4 Le Pan tablet, I got to switch wifi or bt on and it tries for a couple seconds then goes back to off. Sometimes it won't even let me click it on at all, the button is completely faded out. Help!
    10-09-2017 10:08 AM
  6. Ranvir Singh2's Avatar
    05-05-2018 12:15 AM
  7. Ranvir Singh2's Avatar
    If you don't know what the Franco kernel is then you haven't flashed it, the only thing I can think of is if you've rooted your device and disabled some of the system apps then that can cause bluetooth and/or wifi to stop working but if you've not rooted then you'll have to wait for a few more people to view the post and get another opinion.... Sorry pal.
    Sent from my Nexus 7 using Tapatalk
    I have the same issue.
    But i have rooted my android jellybean device and done nothing after that.
    Plzzz help me to fix the problem.
    05-05-2018 12:19 AM
57 123
  1. Replies: 37
    Last Post: 09-29-2016, 08:18 PM
  2. Note 3, KitKat, /sdcard, External SDCards, and...
    By trparky in forum AT&T Samsung Galaxy Note 3
    Last Post: 04-25-2014, 04:12 PM
  3. Camera: HTC One (M8) vs Olympus D40 point-and-shoot
    By CarrierPigeon in forum HTC One M8
    Last Post: 03-27-2014, 05:52 PM
  4. Replies: 1
    Last Post: 03-27-2014, 04:30 PM
  5. WiFi Disconnects during voice calls - how to fix this?
    By BlueOrbit in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-27-2014, 03:48 PM
