Help with bad Battery life
Hgouck
213
I had an experience today- my Battery dropped 35% in 2 hours. It got me thinking how we as a community can help others identify how to avoid a bad battery experience. I hope others will chime in with suggestions.
What I did was run a Mobile Hotspot in a weak signal area. It Drained my phone and my tablets battery excessively. I would not recommend doing this.
What suggestions might you have to avoid running low on battery between charges?
SigmundSL
63
Turn off the unnecessary radio connections like Wifi, NFC or Bluetooth; only have the apps that you really need installed, don't use Task Killers and also setup the brightness on the phone at a low level. That will help a lot.
doogald
Trusted Member
Jan 3, 2010
4,425
55
The maxx supports both the android device manager and motorola's version that basically does the same thing. Don't use both. Choose one or the other from settings / security and screen lock / device administrators and choose either Motorola device policy or android device manager (or neither if you don't need it.)
Laila Nance
