1. Hgouck's Avatar
    I had an experience today- my Battery dropped 35% in 2 hours. It got me thinking how we as a community can help others identify how to avoid a bad battery experience. I hope others will chime in with suggestions.
    What I did was run a Mobile Hotspot in a weak signal area. It Drained my phone and my tablets battery excessively. I would not recommend doing this.
    What suggestions might you have to avoid running low on battery between charges?
    11-06-2014 06:28 PM
  2. SigmundSL's Avatar
    Turn off the unnecessary radio connections like Wifi, NFC or Bluetooth; only have the apps that you really need installed, don't use Task Killers and also setup the brightness on the phone at a low level. That will help a lot.
    Hgouck likes this.
    11-06-2014 06:59 PM
  3. doogald's Avatar
    The maxx supports both the android device manager and motorola's version that basically does the same thing. Don't use both. Choose one or the other from settings / security and screen lock / device administrators and choose either Motorola device policy or android device manager (or neither if you don't need it.)
    steph1488 and Hgouck like this.
    11-06-2014 07:47 PM
  1. Replies: 9
    Last Post: 01-14-2015, 12:17 AM
  2. How much battery timing you think is normal ?
    By Zain Bin Tariq in forum Hardware Hideaway
    Last Post: 11-07-2014, 01:49 AM
  3. Verizon Motorola Droid Turbo Battery %
    By fofjjsr in forum Motorola Droid Turbo
    Last Post: 11-06-2014, 07:57 PM
  4. Replies: 1
    Last Post: 11-06-2014, 07:01 PM
  5. Help: Can't select Vibrate when ringing on Galaxy s5
    Last Post: 11-06-2014, 05:12 PM
