1. craigb_ma's Avatar
    New behavior in my Droid Maxx. I cannot get bluetooth, wifi, or mobile hot spot to turn on. There are no apparent errors displayed when I attempt to turn on any of them. Device is not in airplane mode as normal over the air voice/data is fine connecting to both 3G & 4G LTE modes.
    Bluetooth screen. I tap the On button, a message comes up stating that its turning on Bluetooth, but after 5 seconds it still lists as Off and no BT icon appears on my status bar.
    Wifi: I tap the On button and instantaneously it goes back to the Off position. I've tried turning Wifi on via several different apps and menus, but all have the same result. Wifi icon never appears in status bar.
    Hotspot: I have a data plan that includes hotspot, and it's always worked up until now. Same behavior as bluetooth where I click the check box in Settings to turn it on, but after a few seconds the box is simply unchecked again. No error message displayed.
    Separately, I've also noticed that the "your app will work better/faster on Wifi" for many apps like Googlemaps. The checkbox in settings that allows me to turn off that prompt is greyed out and I cannot change it.
    Any thoughts?
    version info:
    android 4.4.4
    system:23.3.24
    12-02-2014 02:19 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! See what happens if you boot into Recovery and wipe the cache partition: Wipe Cache Partition DROID Mini DROID Ultra DROID Maxx by Motorola | Verizon Wireless
    12-04-2014 01:35 AM
  3. doogald's Avatar
    Do you happen to have an app called tiny flashlight installed?
    http://forums.androidcentral.com/mot...ml#post3863258
    If not that, maybe it's another app causing the issue. Try restarting in safe mode. Long press power as you usually would to power off, but this time long press the "power off" button until you get the message to restart in safe mode. See if you still have the problem.
    If that doesn't fix it, to rule out a hardware error I'd suggest a factory data reset. Don't restore after the reset. You can always quickly do another to do a restore. See if the problem returns. If so, it's probably a hardware error.
    Of course backup all of your photos and videos before the reset.
    12-04-2014 06:52 AM
  1. Why have my Android devices stopped connecting to wifi?
    By Deano777 in forum General Help and How To
    Last Post: 12-04-2014, 01:43 AM
  2. Replies: 2
    Last Post: 12-03-2014, 05:49 PM
  3. How do I turn off the blue tips?
    By j_grouchy in forum LG G3
    Last Post: 12-03-2014, 03:52 PM
  4. fails on boot downloading screen
    By Daniel Estrada1 in forum Ask a Question
    Last Post: 12-03-2014, 12:14 AM
