kevinstrehle
Went ahead and just did the factory reset... Phone was running slow anyway and was probably about time to do it. No clue what caused the issue.
In the past there have been people who had an issue where the wifi radio would not turn on at all get fixed by uninstalling a flashlight app (I'm not sure which one), but this problem is different. Those people (there were more than one) would find the wifi radio switched off and, when toggled on, would turn right off again.
Thank you guys for all your posts, this is exactly the same behavior that I just started to experience this past week. Turning airplane mode on temporarily fixes the problem, but as was mentioned, it does not reconnect. What is strange is that I only experience this issue on my home network - my phone connects to my work network without any issues. I have been running the phone all day now in Safe Mode, and I will see if it automatically connects when I get home. Is the general consensus this is an app issue?
Just a quick follow up: when I arrived back home with my device in Safe Mode, it immediately connected to Wifi. I think this indicates the issue to be caused by a third party app.
I had identical problem, went to Verizon store, couldn't connect to a hotspot, was advised to try hard reset. When that didn't work they gave me a free phone under 1 yr. warranty and new phone works perfectly! I also have the same Asus router.
