1. v1ru5879's Avatar
    I noticed now after I did a FDR on my Maxx the stock camera app isnt the same. I used to have the focal point and option to darken or lighten now all i have is just what seems to be the old camera before they added extras to the update. Any info on how to correct this? Or is there a much better camera app I should use?
    10-08-2015 04:03 PM
  2. doogald's Avatar
    There should be an update to the camera app in the Play Store. I'd look there first.
    10-08-2015 06:20 PM
  3. v1ru5879's Avatar
    Already tried that :/
    Sent from my XT1080 using Tapatalk
    10-08-2015 06:21 PM
  4. doogald's Avatar
    Settings / applications. Find the camera, tap it, tap uninstall updates and try to install the update again.
    Also, you have to slide out the options from the left and turn on the tap to focus feature - it's one of the options on the circle menu.
    v1ru5879 likes this.
    10-08-2015 08:56 PM
  5. v1ru5879's Avatar
    Thank you! Been so long since I had updated and learned this feature being as it was always on. Feel like an old man already forgetting stuff lol
    10-09-2015 07:57 AM
  1. Samsung s6 unable to send texts after 5.1.1 Update
    By Logii_macd in forum Samsung Galaxy S6
    Last Post: 10-29-2015, 01:27 PM
  2. Replies: 12
    Last Post: 10-10-2015, 11:29 AM
  3. Replies: 3
    Last Post: 10-09-2015, 08:20 AM
  4. Replies: 1
    Last Post: 10-08-2015, 03:44 PM
  5. Moto G XT1068 stuck on logo after trying to update system.
    Last Post: 10-08-2015, 01:48 PM
