1. KSean47's Avatar
    A few nights ago, my phone spent the entire night on the charger not charging. I plugged it into a different charger and the battery display showed that it was at 100% in about 20 minutes. After using it for about 5 or 10 minutes, the phone shuts off like it's out of charge while the battery display showed it was at around 90%.
    Either something is wrong with the battery or the OS. Is there a solution for this?
    04-28-2017 09:10 PM
  2. Scott337's Avatar
    You could try a battery calibration, and see if that helps.
    If the device experiences extreme jumps in charging or discharging (5% - 90%) in just a few minutes, follow these steps to calibrate the battery meter and prevent the issue from recurring.
    With the device powered on, press and hold the*Power Button*for 10 - 20 seconds until device restarts.
    Connect the device to the original factory charger and allow*it to charge completely to 100%.
    Continue charging for at least 30 minutes after the unit has reached 100%
    04-28-2017 10:03 PM
  3. doogald's Avatar
    I'd say that the battery is probably shot. Are you sure that it's a 2013 Droid Maxx? I'm not sure when you bought the phone, but mine is now going on four years old. If yours is that old, it wouldn't be surprising for the battery to be worn out.
    04-30-2017 06:34 PM
  4. Mike Dee's Avatar
    The battery in mine still works pretty good
    07-21-2017 07:53 PM
  5. doogald's Avatar
    Same here, but I've hardly used it for 20 months, and it wouldn't be surprising for the battery on a phone that is over two years old to be failing, depending on how heavily the battery was used.
    07-22-2017 07:02 AM
  1. Verizon Galaxy S8+ Clicking Screen Problem.
    By felloffthetruck in forum Samsung Galaxy S8 & S8+
    Last Post: 03-03-2019, 10:29 PM
  2. The Samsung Galaxy S8 has a random reboot problem and nobody knows why.
    By VW Maverick in forum Samsung Galaxy S8 & S8+
    Last Post: 08-15-2017, 12:08 AM
  3. Replies: 0
    Last Post: 04-28-2017, 01:18 PM
  4. Stuck in bootloop after battery drain
    By Unchill in forum HTC One M9
    Last Post: 04-28-2017, 01:06 PM
  5. HTC One M9 stuck in bootloop after battery drained
    Last Post: 04-28-2017, 12:59 PM
