i'm trying my hardest to root my Motorola droid. it came stock with 2.1, and i managed to downgrade to 2.0.1. but the problem i have is using the update.zip file i put on my SD card. when i click apply update.zip i get
D:Can't open /cache/recovery/command
--Install from sdcard...
finding update package...
opening update package...
Verifying update package...
E:signature verification failed
Installation aborted.
any feedback or help would be great. thank you.
