1. Umass021's Avatar
    What is the difference between low voltage kernels and standard? Which one is better to use?
    08-06-2010 02:14 PM
  2. PJnc284's Avatar
    Low voltage kernels should use less power and and theoretically save battery life. Some droids only like the standard voltage kernels so be sure to make a backup in case you start getting bootloops
    Umass021 likes this.
    08-06-2010 02:22 PM
  3. corydunbar's Avatar
    Or if you're real lucky your Droid will accomodate Ultra Low voltage kernels
    08-06-2010 11:22 PM
  4. YoungChrisG's Avatar
    Yeah. Loving the battery life i get while running at 1.25 Ghz at all times with ChevyNo1's Ultra Low 7 Slot.
    08-11-2010 11:59 PM
