I haven't worked with custom roms yet, but I'm sure someone will be able to jump in and give you some direction. Check the other forums, there is a lot of info on rooting and roms. Hopefully you made a backup before loading the new rom from what i've read it looks like you may need it to get stock back. You might also try a different rom, you might like that one better. Good luck.
