Need help
Smitty_82
Android Addict
Aug 8, 2010
1,509
156
I haven't worked with custom roms yet, but I'm sure someone will be able to jump in and give you some direction. Check the other forums, there is a lot of info on rooting and roms. Hopefully you made a backup before loading the new rom from what i've read it looks like you may need it to get stock back. You might also try a different rom, you might like that one better. Good luck.
Smitty_82
Android Addict
Aug 8, 2010
1,509
156
Did you try and install your backup? If that's corrupted you might be able to download a replacement stock rom and give that a try.
Smitty_82
Android Addict
Aug 8, 2010
1,509
156
All I've found is saying to install the stock rom from clockwork. A factory reset was also recomended but I'm not sure that would help for you. Haven't found anything else. Sorry, hopefully someone else will jump in here. I'll keep an eye out if I find anything else that will help.
batsam
