1. kaiser soyze's Avatar
    I flashed cyanogen 6.1.2 stable about an hour ago, I like the look of it, but my contacts are gone, I have been unable to sync to my gmail, and I dont have the market. Is this a simple fix? I am pretty new at this, so would it be better to use a recovery image?
    01-25-2011 06:18 PM
  2. scarryman04's Avatar
    You need to activate your phone with your carrier...*228 if your a VZW customer.
    kaiser soyze likes this.
    01-26-2011 12:03 PM
  3. kaiser soyze's Avatar
    I'll give that a try. Thanks
    01-26-2011 09:29 PM
