1. messymark's Avatar
    Any one have a suggestion to as why it wont work for me ?
    running windows 7 for computer
    droid is running frg83g 2.2.2 kernel version is 2.6.32.9-g68eef5 android-build @apa26 #1
    tried 3 different times last night followed instructions to the T for superoneclick course it could be that i'm a noob at this .
    thanks for any replies
    Messy
    get a chance check out MessyMark.com
    05-17-2011 09:46 AM
  2. messymark's Avatar
    this is the message I keep getting when I click root in superoneclick
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ComponentModel.Win32Exception: The system cannot find the file specified
    at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
    at System.Diagnostics.Process.Start()
    at RageAgainstTheCageGUI.Form1.runCommand(String arguments)
    at RageAgainstTheCageGUI.Form1.runOperationUI(String description, String arguments)
    at RageAgainstTheCageGUI.Form1.btnRoot_Click(Object sender, EventArgs e)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.5444 (Win7SP1GDR.050727-5400)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    SuperOneClick
    Assembly Version: 1.3.0.0
    Win32 Version: 1.3.0.0
    CodeBase: file:///C:/Users/messy/Desktop/SuperOneClick.exe
    Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    05-17-2011 09:59 AM
  3. contractorslim#AC's Avatar
    No offense to the one click rooting ways but this is the most effective way and I have completed it on several droid d1's for friends.
    www .droid-life. com/2010/09/09/how-to-root-motorola-droid-running-android-2-2-frg22d/
    you will have to put the link back together. I dont think I can post them yet.
    06-16-2011 12:01 AM
  4. scarryman04's Avatar
    Check out the [HOW-TO] forum at the top of the page and use the link I posted at the top of the 2nd page for directions to root your phone.
    06-23-2011 08:37 PM
Tags for this Thread
