So I just downgraded from 2.1 to 2.0.1, then got to rooted 2.1, and it was pretty good for the first day.
But now, every five or so minutes, my phone will randomly shut off, and then get stuck on the Droid eye while booting up. This causes me to have to perform a nandroid backup, losing my sms messages which are pretty important to me. Even after I do the nandroid backup its only about 2 hours before the rebooting problem starts, which is very annoying. Idk if its because I installed the overclock widget app (not setcpu as I couldn't find my credit card, but I found it so would this be a better option?) because everything was working pretty good before that.
Also, if its not the rebooting problem, everything will just force close, causing tons of force close messages to appear.
These problems have prevented me from being able to put a custom ROM on my phone, which is pretty annoying.
I saw that there is a way to root the stock 2.1 now (but there is no guide) however, would this be a better option or no?
So what do you think is wrong with my phone, and how can I correct it?
