How are you guys getting such good battery life? I'm averaging 4-5 hrs SOT, no more no less, when running the battery close to empty. I have my screen set to 40% with adaptive brightness and everything on except for bluetooth and location set on battery saving. With moderate use this gets me through about 1.3 days, with light use I can eek 2 days out of it, but I can kill my phone in less than a day if I use it very heavily.
When the phone is on idle, it sips battery as if it already has Doze (usually 3% lost overnight). However, using the screen murders the battery. From my loose observations, the battery literally drains 1% about every 3 minutes of SOT. I can post screenshots later when my battery runs low later.
Also, for some reason, my screen is not the biggest battery drain most of the time, but it doesn't seem to be a rogue app either. It's usually Google Play Services, Android OS, Android System, Google App, or cell standby at the top, with screen 2nd or 3rd.
Can anybody help? The battery life is good but I feel like my phone is under-performing compared to some of the guys on this forum.
