12-24-2015 01:27 PM
117 123 ...
tools
  1. THEPRFCT10's Avatar
    So I was the first at my store to get the Turbo 2. Looking forward to seeing if the battery life is indeed as good as advertised with moderate use. Charged to full at 730pm last night now 830am and its at 58%. We'll see! Anyone else?
    dmark44 likes this.
    10-30-2015 07:33 AM
  2. russel5150's Avatar
    I have not really checked mine yet because I have been on it more than usual setting it up but so far it seems to be on par with the turbo from last year.
    Moto Droid Turbo 2
    10-30-2015 01:47 PM
  3. THEPRFCT10's Avatar
    Moto Droid Turbo 2
    Same here more like moderate to heavy use setting up!
    10-30-2015 02:30 PM
  4. PowrDroid's Avatar
    You should see a gradual increase in battery life as you go through charge cycles and the battery gets conditioned. Important thing to remember is to not let it get below 15% - 20% charge, if you can help it.
    10-30-2015 02:33 PM
  5. THEPRFCT10's Avatar
    Thanks for the advice at 34% now so not quite 24 hours
    10-30-2015 02:36 PM
  6. PowrDroid's Avatar
    I presume you were playing with your phone quite a bit between 7:30 pm and whenever you ended for the night. Biggest battery drainer is screen on time, especially a bright screen. I've gotten 7+ hours screen on time at about 35% screen brightness with my T1. Curious to see how the T2 performs.
    10-30-2015 02:36 PM
  7. PowrDroid's Avatar
    I'd love to see screenshots of your battery use graph, and also your screen on time. I'm sure others would love to see it as well.
    10-30-2015 02:38 PM
  8. THEPRFCT10's Avatar
    You would be correct
    10-30-2015 02:39 PM
  9. THEPRFCT10's Avatar
    Lol sure... Uh how do I screenshot!
    10-30-2015 02:40 PM
  10. jmanches4286's Avatar
    Volume down and power at the same time
    10-30-2015 02:42 PM
  11. THEPRFCT10's Avatar
    Lol thanks! Damn the learning curve
    10-30-2015 02:50 PM
  12. THEPRFCT10's Avatar
    10-30-2015 02:51 PM
  13. THEPRFCT10's Avatar
    Let me know if they came thru
    10-30-2015 02:56 PM
  14. PowrDroid's Avatar
ID:	203820Click image for larger version.
    Nicely done.
    These screenshots are useful. The other one is once you are on this screen, if you tap on
    and then take a screen shot of the screen time on, that would give us the two most important battery usage factors.
    10-30-2015 02:59 PM
  15. THEPRFCT10's Avatar
    How's battery life on the DROID TURBO 2?-uploadfromtaptalk1446235398489.jpg how's this?!
    will1881 likes this.
    10-30-2015 03:03 PM
  16. THEPRFCT10's Avatar
    I'm guessing somewhere between 20-30% is the optimal time to charge to full?
    10-30-2015 03:08 PM
  17. PowrDroid's Avatar
    how's this?!
    BINGO! That's it. Almost 4 hours of screen on time and it only used 14% of battery. That is somewhat amazing. IIRC, my T1 screen uses about 30% of battery after 4 hours screen on time, maybe more than 30%. Your lookin' good.
    10-30-2015 03:11 PM
  18. PowrDroid's Avatar
    Yes, I wouldn't let it get much below 20%. At this time you could charge it for 15 minutes and test Moto's claim that it yields 13 hours of additional usage. Just remember to plug it in tonight so it can charge up fully.
    10-30-2015 03:13 PM
  19. THEPRFCT10's Avatar
    Cool thanks ironically enough, the Verizon guy yesterday told me NOT to plug it in overnight. He said that's bad for the battery I said I never heard that and it's common practice for everyone I know lol! I know with Samsung once the phone reaches 100%, the phone knows not to charge anymore but stays in a pulsing mode to keep at 100% until it's unplugged. Some smart circuitry or something
    10-30-2015 03:22 PM
  20. PowrDroid's Avatar
    I would guess 99.9% of all battery chargers have a circuit that shuts down the charging when the battery reaches a full charge. It's a pretty basic design feature. I wouldn't worry about plugging it in overnight.
    10-30-2015 03:36 PM
  21. THEPRFCT10's Avatar
    Me too! Thanks!
    10-30-2015 03:37 PM
  22. THEPRFCT10's Avatar
    Wow! The battery definitely gets very hot while "Turbo" charging!
    10-30-2015 06:04 PM
  23. copywrite's Avatar
    Yes! Definitely will be using a regular charger for night charging.
    10-30-2015 06:08 PM
  24. THEPRFCT10's Avatar
    Uh a "regular" charger?! Mine only came with one. Why wouldn't the one that came with it not be good to charge overnight?! Note I'm confused...
    10-30-2015 06:09 PM
  25. copywrite's Avatar
    I am using the charger from my Droid Maxx, but any old micro with a plug will do. They pump out less juice which in turn doesn't heat up the battery, which is not good for the battery's long term health. A slow charge is much better at night there is plenty of time for it to charge. I will use the turbo charger only when it is needed.
    elvee68 likes this.
    10-30-2015 06:30 PM
117 123 ...
  1. my goggle music isn't playing on my galaxy 5
    Last Post: 11-28-2015, 08:01 PM
  2. Replies: 2
    Last Post: 11-07-2015, 02:06 PM
  3. Replies: 1
    Last Post: 11-03-2015, 10:52 PM
  4. How to tell what is killing battery intermittently
    Last Post: 11-02-2015, 07:43 PM
  5. How to fix "Unfortunately Mobile App has stopped"
    Last Post: 11-02-2015, 12:37 PM
