1. THEPRFCT10's Avatar
    Just noticed the turbo charger that came with the turbo 2 DOES NOT come apart to reveal a usb connector like most other phones, so how does one connect this phone to a computer for file exchange and whatnot?! Help appreciated! Thanks.
    11-02-2015 08:54 AM
  2. kmf1's Avatar
    Any USB cord should work. What phone did you have before the new T2?
    11-02-2015 08:56 AM
  3. THEPRFCT10's Avatar
    Had Samsung Galaxy S4 which had the charger that came apart to reveal a USB port to connect the phone to the computer. Wow, I am completely unaware that I needed to purchase a separate cable to connect this phone to the computer. I thought the charger comes apart so that we can connect the phone to the computer.
    11-02-2015 08:58 AM
  4. viper8315's Avatar
    I'm pretty sure it's done intentionally due to the high current needed for the quick charging. They don't want you connecting anything but a cable spec'd to handle the current that the charger can output. As far as buying something, any Micro-USB to regular USB cable will work. It doesn't need to be anything specific. I don't know about you, but over the years of smartphone ownership, I have probably 6-10 cables around the house. If you do need to actually buy something, just go to Walmart and get the cheapest micro USB cable you can find. Amazon is even a better place for cheap cables that work just fine.
    dmark44 and YAYTech like this.
    11-02-2015 09:15 AM
  5. THEPRFCT10's Avatar
    Great thanks!
    11-02-2015 09:15 AM
  6. Alienpup's Avatar
    This is the fattest charging cable I've ever seen. Must be moving some juice. Funny thing is I just tried connecting my Nexus 6 charger (cable is detachable) to the t2 and the moto clock widget says turbo power, same as with the stock charger. Old lg g3 charger does not say turbo power when charging.
    11-02-2015 10:13 AM
  7. viper8315's Avatar
    That is the beauty of devices that meet the same specifications. Any turbo, fast charge (whatever it's labeled) charger that is certified to work with Qualcomm's quickcharge 2.0 should activate the "turbo" charging mode of the T2.
    YAYTech likes this.
    11-02-2015 10:59 AM
  1. You can order a replacement Moto Shattershield Lens from Motorola
    By viper8315 in forum Motorola Droid Turbo 2
    Last Post: 11-09-2017, 03:19 PM
  2. Replies: 2
    Last Post: 11-07-2015, 02:06 PM
  3. Replies: 1
    Last Post: 11-03-2015, 10:52 PM
  4. How to tell what is killing battery intermittently
    Last Post: 11-02-2015, 07:43 PM
  5. How to fix "Unfortunately Mobile App has stopped"
    Last Post: 11-02-2015, 12:37 PM
