1. dpham00's Avatar
    The maximum brightness on the turbo 2 is slightly dimmer than the note 5 without auto boost. Once auto boost kicks in on the note 5, it would be much brighter.
    Here is a comparison on max brightness without auto boost on the note 5.
    Any way to increase the brightness on the turbo 2 beyond what is allowed in the settings?
    Turbo 2 maximum brightness is not that bright... Any way to increase it?-uploadfromtaptalk1446731922794.jpg
    11-05-2015 09:00 AM
  2. Golfdriver97's Avatar
    Rooting and maybe Xposed Framework might be able to change the brightness settings.
    11-05-2015 09:13 AM
  3. Gunner's Avatar
    Have you turned off adaptive brightness?
    anon(5002059) likes this.
    11-05-2015 09:59 AM
  4. russel5150's Avatar
    This what i was going to suggest.
    I have both the turbo2 and the note5. My advice to you is to not try and compare the two, the note5 is an industry leading screen, and the turbo2 while a great screen is made to be rugged, so you sacrifice a little bit of quality.
    Samsung usually gets brighter than motorola, but like i said, they are two different types of screens.
    Moto Droid Turbo 2
    perkdog65 likes this.
    11-05-2015 11:11 AM
  5. dpham00's Avatar
    The shot above was with adaptive brightness disabled
    11-05-2015 12:01 PM
  6. benjamminh's Avatar
    All those screen layers have an effect. The DT2 screen is dim to me, but I agree if you don't use another phone to compare it with you'd probably get used to it and be fine.
    11-05-2015 01:08 PM
  7. SupraLB's Avatar
    I saw a review the other day that listed all the top phones brightness levels. Unfortunately, T2 was at the bottom. Makes no sense because with that big battery, they could certainly up the juice.
    11-05-2015 02:04 PM
  8. beeare's Avatar
    It was still better than the T1, which coming off the T1 is very important to me. I was worried it might actually be lower than that based on what I've read from the initial impressions, but there was no doubt the screen on the T2 was brighter than the T1. The T1 was nice, but never S6 or Note 5 quality. So just because it's not at the absolutely elite level, doesn't mean it's not nice. I think the screen is definitely solid, and I'm happy with it. This all just boils down to what you prefer in a phone subjectively. If screen is your most important feature, then the T2 might not be your best choice. But it still has an excellent screen, and when you weigh in all of the other features, it makes one of the best phones on the market today with out a doubt. Based on my list of prized features, I rank screen high, but other things slightly higher. Once I saw the screen was up to par, it was no brainer to me that this would be my next phone. If you really find the brightness level unsatisfactory, I think you must be comparing it side by side with one of the true elites, but on its own, I doubt anyone would really think anything else other than the screen looks really nice.
    11-05-2015 02:38 PM
  9. elvee68's Avatar
    Turn off adaptive brightness and it gets more brighter.
    11-05-2015 03:49 PM
  10. benjamminh's Avatar
    http://www.theverge.com/2015/11/6/96...2-review-specs The Verge (not a great source I know) slams the quality of the screen. I think they went a little too far but from what I've seen in the store it is significantly dimmer and less vibrant than my Pure screen.
    11-06-2015 03:21 PM
  11. dpham00's Avatar
    I like the note 5 screen better but the turbo 2 screen quality is perfectly fine for me,other than the brightness.
    dmark44 likes this.
    11-06-2015 04:09 PM
  12. Bill Gassman's Avatar
    Moving from Samsung S5 to the T2, the brightness is one of a few differences I'll miss. It is not just brightness, but also contrast. Looking at a picture of a tree, the S5 shows more of bark. There is many variations of shadows. The T2 shows smooth surfaces where the S5 shows texture. I'm sure that I will get used to it, but people should know there is a significant difference. BTW, I'll also miss the IR blaster and image stabilization.
    12-02-2015 08:10 AM
  13. elvee68's Avatar
    Turning off Adaptive Brightness off will make the display brighter.
    12-02-2015 08:45 AM
  14. 18t's Avatar
    Ugh, don't remind me of IR blaster. It's been a painful change.
    12-02-2015 09:37 AM
  15. tlacour's Avatar
    My eyes must not be as sensitive to dynamic range as most. I was also worried about a dim screen after reading negative reviews about the T2. I have been very pleased with the display. It looks brighter and sharper than my wife's note 4. When I walk thru the local Verizon store and hold the T2 side by side to other devices, I don't see much of a difference. Yes the newest Samsung phones are a bit brighter and the displays seem to have more of a "pop" to them, but that's their thing. Even so, it is barely noticeable to me. Admittedly, I usually keep my display at about 75% because that seems to be a good brightness level for me.
    12-02-2015 10:13 AM
  16. Mattsg430's Avatar
    Brightness is fine to me. Brighter than my turbo 1 for sure and whiter whites. The turbo 1 also has a much more yellowish tint than the turbo 2. I did play around with the note 5 in the store and it is brighter, but like most people here, I'm assuming you bought the turbo 2 for its other screen feature....
    12-02-2015 12:50 PM
  1. what is programdata in storage<misc.
    Last Post: 11-05-2015, 06:48 PM
  2. How can I get my LG phone to pair with my Mercedes GLK 350?
    Last Post: 11-05-2015, 06:47 PM
  3. Replies: 1
    Last Post: 11-05-2015, 06:42 PM
  4. How can I get my Note 4 fingerprint lock working?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 11-05-2015, 09:09 AM
  5. my note 4 fingerprint lock is not working?
