Is there LED notifications on this phone? I see it in the settings but haven't once seen an led light up since I've had the phone
Well then I'm glad we have the option to change to color of non existent leds
When I go into my messaging. And go to the settings. I can choose different led notification colors
Nope, in-between the flash and the earpiece.That's the flash for the front-facing camera, I believe.
Like I said, the same LED on the Moto X and Nexus 6. Which has been successfully hired to perform notification duties on rootThere is a single LED on the T2, but that is the SOL LED. You can read that as "**** Outta Luck" or "Sign Of Life". Basically, it blinks to tell you that your battery is real low and you're gonna have to wait for it to charge back up a little bit. Otherwise, it turns off and is not used for notifications.
On the Moto X is the led multicolor?Like I said, the same LED on the Moto X and Nexus 6. Which has been successfully hired to perform notification duties on root
Hopefully this can and will be achieved without root. Only thing I worry about will be dev. support based on this phone being a verizon exclusive, although I wonder if the unlocked (moto pure X ???) variant would be able to use the same type of development.
