04-22-2018 10:07 PM
40 12
tools
  1. Josh Burzycki's Avatar
    Is there LED notifications on this phone? I see it in the settings but haven't once seen an led light up since I've had the phone
    11-09-2015 12:52 PM
  2. djousma's Avatar
    No LED's.
    11-09-2015 01:08 PM
  3. Ry's Avatar
    No. Moto Display is it's replacement.
    DLewis13 likes this.
    11-09-2015 01:10 PM
  4. Josh Burzycki's Avatar
    Well then I'm glad we have the option to change to color of non existent leds
    11-09-2015 01:22 PM
  5. Ry's Avatar
    Where?
    11-09-2015 01:24 PM
  6. Josh Burzycki's Avatar
    When I go into my messaging. And go to the settings. I can choose different led notification colors
    11-09-2015 01:30 PM
  7. Ry's Avatar
    Verizon Messages app probably doesn't know that it's not available.
    11-09-2015 01:55 PM
  8. chris20nyy's Avatar
    Turbo 2 has an LED just to the left of the earpiece. So far the only color I've seen was green. But its there. Similar to the Moto X and Nexus 6
    11-09-2015 11:39 PM
  9. CharlieL3's Avatar
    That's the flash for the front-facing camera, I believe.
    11-10-2015 09:20 AM
  10. chris20nyy's Avatar
    Nope, in-between the flash and the earpiece.
    tamaralynne2346 and SEPA30 like this.
    11-10-2015 11:10 AM
  11. strawbee's Avatar
    There is a single LED on the T2, but that is the SOL LED. You can read that as "**** Outta Luck" or "Sign Of Life". Basically, it blinks to tell you that your battery is real low and you're gonna have to wait for it to charge back up a little bit. Otherwise, it turns off and is not used for notifications.
    11-10-2015 11:12 AM
  12. chris20nyy's Avatar
    Like I said, the same LED on the Moto X and Nexus 6. Which has been successfully hired to perform notification duties on root
    11-10-2015 11:23 AM
  13. rdjr74's Avatar
    Hopefully this can and will be achieved without root. Only thing I worry about will be dev. support based on this phone being a verizon exclusive, although I wonder if the unlocked (moto pure X ???) variant would be able to use the same type of development.
    11-10-2015 12:20 PM
  14. Ry's Avatar
    There's an LED. But it doesn't act as a Notification LED. You may need to root to get it working.
    11-10-2015 12:30 PM
  15. recDNA's Avatar
    On the Moto X is the led multicolor?
    11-10-2015 12:42 PM
  16. chris20nyy's Avatar
    I'm not sure, I've never implemented. I've grown so accustomed to active notifications I have no interest. I think the info is out there though
    Ry and Davidoo like this.
    11-11-2015 02:25 PM
  17. recDNA's Avatar
    Moto hooked me on multicolor led notifications in my og droid. Ironic that they were the first to dump them. That Droid was one hell of a phone for its era.
    sherri and tamaralynne2346 like this.
    11-27-2015 08:20 AM
  18. will1881's Avatar
    think you mean moto x force, yes i really want LED. especially if moto display only "breathes" for 3 minute and then you're SOL lol
    11-27-2015 02:46 PM
  19. K_Quinn's Avatar
    Has anyone noticed the sensor on the right, right next to the ear piece. Has that turned red for anyone else?? It was red twice 2 days ago and hasn't done it since.
    11-30-2015 08:40 AM
  20. Aaron Payton's Avatar
    the sensor to the right of the earpiece that glows red when the screen goes off is the proximity sensor for moto display. If you look on the bottom there is two more that do the same thing.
    12-02-2015 06:37 PM
  21. recDNA's Avatar
    Too bad they're not accessible for notifications.
    tamaralynne2346 likes this.
    12-05-2015 08:58 AM
  22. tamaralynne2346's Avatar
    why doesn mine work? where are the settings
    12-30-2015 10:18 AM
  23. tamaralynne2346's Avatar
    none of y lights work, any idea why? im not moto savvy can you help?
    12-30-2015 10:22 AM
  24. doogald's Avatar
    There is no LED notification light. There is no setting, there is nothing to turn on. Moto Display is Motorola's replacement for the blinking LED.
    12-30-2015 10:52 AM
  25. Robert Beier's Avatar
    If you read the thread it is explained that there's no LED for notifications. Settings for Moto display are under the Moto app.
    12-30-2015 10:53 AM
40 12
  1. Ditch my S6 edge for the Nexus 5x?
    By Matt Scruggs in forum Nexus 5X
    Last Post: 11-28-2015, 11:39 AM
  2. Does the note5 have multiple notification on messages?
    Last Post: 11-09-2015, 02:59 PM
  3. Replies: 0
    Last Post: 11-09-2015, 01:51 PM
  4. Replies: 1
    Last Post: 11-09-2015, 01:36 PM
  5. On my galaxy S6 text talk stopped working.Why?
    Last Post: 11-09-2015, 01:20 PM
