Protect your tech:Get an Upsie warranty & save up to 70%
  1. THEPRFCT10's Avatar
    I've looked and can't find what they mean. Service and WiFi still work when the exclamation point appears but can't find out what out means. Help appreciated.
    11-17-2015 04:44 PM
  2. PapaGary's Avatar
    On my 1st gen Moto X the exclamation point shows it is connecting and only lasts a second or two.
    11-17-2015 05:02 PM
  3. kmf1's Avatar
    I know that with the WiFi icon, it means that you are not connected to a network. Like hotel/motel WiFi networks, where you have to sign in. Then the exclamation point disappears. Occasionally my 4G icon has an exclamation point by it too. Rarely though.
    11-17-2015 05:02 PM
  4. Javier P's Avatar
    That exclamation mark means that your device can't connect with Google servers. It's strange that it appears even when you are connected to a network. Is it still there if you switch WiFi off & on?
    11-17-2015 05:06 PM
  5. THEPRFCT10's Avatar
    Yes but only temporarily.
    11-17-2015 07:27 PM
  6. Andyland's Avatar
    Mine is doing the same thing the WiFi works for a while but then does this and I lose all connectivity
    Attached Thumbnails What's the exclamation point next to the signal strength bars or WiFi?-screenshot_2015-11-29-10-25-32.jpg
    12-04-2015 12:17 AM
  7. rdjr74's Avatar
    I'm guessing there is a wifi network available. If you have wifi turned on but not connected to a network, pull down your notification bar and you will see the same icon.
    12-04-2015 12:03 PM
  8. Andyland's Avatar
    yes i do see that icon when i pull it down, however the wifi does work i am logged in on my computer replying to you as we speak. The Wifi works fine on my LG G4 my Nexus 6 and my iPhone 6 as well as my computor and my Amazon fire stick. Just not my Turbo 2!
    12-04-2015 02:14 PM
  9. Jeeperjk's Avatar
    Changed both mine and my partners router IP from 192.168.0.1 to 192.168.1.1 and all android, Apple and windows phones/tablets now connect and the exclamation mark is gone...
    02-01-2016 12:16 AM
  10. THEPRFCT10's Avatar
    Ok so that's weird! Still doesn't explain what it means!
    02-01-2016 06:29 AM
  11. doogald's Avatar
    Let me guess - you connected a router to a device from your isp that is also a router? And the isp's router was using 192.168.0 addresses?
    Just as an explanation, whenever you place a router within another router like that, you have to change it to use a different IP address range or the packets will never leave the inside router. (Or you can change the router that you installed to bridge mode, so that it is not routing but is part of the isp's router address range.)
    It's a little complicated, and it's too bad that routers aren't designed to look for this configuration and automatically change the private IP address to something else automatically (there's no reason why that couldn't happen.)
    02-01-2016 06:54 AM
  12. Jeeperjk's Avatar
    Connecting direct to an optus supplied cable modem with wifi at mine, an optus supplied NBN modem with wireless at my partners... No router attached to ISP modem set ups...
    02-03-2016 05:10 AM
  13. NucleBAH's Avatar
    Optus hey? Maybe that's the problem? My Optus internet back when I lived in Perth was awful.
    02-04-2016 04:26 PM
  1. Can the Cloecud Android be used internationally?
    Last Post: 05-10-2018, 07:39 PM
  2. Replies: 2
    Last Post: 11-27-2015, 08:49 PM
  3. Problems with FORWARDED calls to my phone
    By angelbones1 in forum Google Project Fi
    Last Post: 11-18-2015, 10:03 AM
  4. What do different colored icons next to text messages mean?
    Last Post: 11-17-2015, 03:53 PM
  5. Replies: 1
    Last Post: 11-17-2015, 03:50 PM
