1. K_Quinn's Avatar
    I cannot figure out how to change my calendar widget!
    First picture is from my Samsung S4. This is what I need it to look like. It looked like this on my Moto Droid Razr that I had before the S4 but I don't remember how to do it.
    Calendar widget and the non existent LED light..-screenshot_2015-11-19-12-00-28-1-.jpg
    This is what the stock calendar widget and the Google calendar that I downloaded both look like. I really want the month view just up without having to go into the calendar.
    Calendar widget and the non existent LED light..-screenshot_2015-11-19-12-21-17.jpg
    As for the LED light.. I know it's not there, but what I'm trying to figure out what are all the holes on the upper and lower display?
    Left to right top
    Flash- no idea-no idea- no idea- and camera
    bottom 2 things on the outsides of the speakers
    What are those?
    With the option of changing the LED colors could a future update give the option of having the LED notification back? Are one of those holes where that would be?
    11-19-2015 12:33 PM
  2. russel5150's Avatar
    Those little holes are sensors. No led, the option to change colors is something made into lollipop, motorola does not use led. They use the moto display which a lot of us like better than an led.
    As far as calander i miss the samsung calander. I use the app called month calander, its the only one i have found i like that has a full month widget that you can see w out having to touch it.
    Moto Droid Turbo 2
    K_Quinn likes this.
    11-19-2015 01:13 PM
  3. tlacour's Avatar
    I use a Calendar widget that shows a month view.
    https://play.google.com/store/apps/d....chronos&hl=en
    Loads of display options. You can set it up to bring up the daily appts when you touch a day and go to stock calendar to add and edit appoints.
    jmanches42, dmark44 and K_Quinn like this.
    11-19-2015 05:42 PM
  4. K_Quinn's Avatar
    That calendar worked perfectly! Thanks!
    dmark44 likes this.
    11-19-2015 07:23 PM
  5. chris20nyy's Avatar
    Droid Turbo 2 has an LED in-between the left sensor group and speaker. I've only seen it lit up green. Not sure if it has any other colors
    11-23-2015 05:00 AM
  6. russel5150's Avatar
    What did you do to make it light up?
    Moto Droid Turbo 2
    11-24-2015 07:12 AM
  7. doogald's Avatar
    If it's anything like the moto X and droid phones since 2013, it's only a low battery indicator (when you plug in, to indicate the theft there is not enough battery to turn on the display) and cannot be used for notifications (until somebody figures out a permenant root for the phone.)
    11-24-2015 10:32 AM
  8. chris20nyy's Avatar
    Moto Droid Turbo 2
    It was the ultra low battery warning that Moto phones (X, Turbo, Turbo 2, nexus 6) use. It's been successfully modded to be used for notifications on rooted devices.
    11-25-2015 03:56 AM
  1. Where is the hold button?
    Last Post: 11-19-2015, 06:00 PM
  2. How do I sync my Samsung 5S calendar to my gmail account?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 11-19-2015, 05:01 PM
  3. Does the Verizon cloud transfer Calendar info?
    Last Post: 11-19-2015, 12:33 PM
  4. would the att lumia 640 work perfect on tmobile?
    By Goosinurwife in forum AT&T
    Last Post: 11-19-2015, 12:29 PM
  5. two questions: email and onedrive
    By ccrusher in forum Samsung Galaxy Note 5
    Last Post: 11-19-2015, 12:27 PM
