12-01-2015 10:09 PM
61 123
tools
  1. Masheen's Avatar
    My battery has been getting destroyed the last couple of days. The phone's radio is staying active somehow.
    Attached Thumbnails Battery Drain Issues &  Resolutions-1448029482266.jpg   Battery Drain Issues &  Resolutions-1448029493466.jpg
    11-20-2015 08:25 AM
  2. viper8315's Avatar
    Maybe try a reboot? I notice your WiFi signal is only 50%, maybe you're dropping off WiFi without knowing? There is a setting in the WiFi settings that will avoid poor internet connections.
    11-20-2015 08:36 AM
  3. Masheen's Avatar
    Optimum WiFi is a blessing and a curse. If I save my login for it, when I drive it probably goes crazy. The handoffs have been great with the last DT1 update and now with the DT2, but it still is annoying when it interrupts gps to do so and I miss a turn lol.
    11-20-2015 08:57 AM
  4. viper8315's Avatar
    Yea, you're probably spending more time on cell data than you think. I tried those cable WiFi's for a while, but had more trouble using them than it was worth. If you want to run an experiment, go into your WiFi settings and see what the option for avoiding poor internet connection says. If the setting is ON, turn it OFF, and see what happens. It that setting is already OFF, then well, my theory is kind of busted.
    11-20-2015 09:11 AM
  5. Masheen's Avatar
    I had it checked to avoid poor connections. This is an all of the sudden thing though. I've had the phone for two weeks and this is the first time cell standby is chunking down my battery life. Reset didn't work, might just factory reset for fun.
    11-20-2015 09:55 AM
  6. ibcop's Avatar
    A factory reset is never fun. Lol
    Masheen, shadowsjc and dmark44 like this.
    11-20-2015 11:14 AM
  7. Masheen's Avatar
    Can someone tell me why the dialer And contacts app needs to constantly ping location? They're always on the list.
    11-20-2015 11:32 AM
  8. sava700's Avatar
    I returned my Turbo 2 the other night and got a new one - The reasons was for #1 the screen cover is so soft that I sliced it slightly and I wasn't aware it would do that but I was gonna be patient for that and maybe not but then Thurs I noticed I was down to 50% with hardly using the phone - put it on the charger it got really hot and hit 100% and restarted on its own. Once it came back up it corrupted two apps to the point I had to start uninstalling them just to figure out if an app was the problem. The corruption caused the screen to go blank and lock up. Needless to say I wasn't happy and there was no way I was gonna wait another day to go tell them and get it replaced as I was still within the 14 day time frame. I made it clear that the replacement started a new 14day period and that I would watch this one like a hawk.
    11-21-2015 08:14 PM
  9. Masheen's Avatar
    Dam. That's a rare and unfortunate situation. Hope your new one works as intended.
    11-21-2015 08:32 PM
  10. Robin Hebert's Avatar
    I've had a few tweaks but not that...
    11-21-2015 09:04 PM
  11. Masheen's Avatar
    Being in a low service zone causes Cell Standby to go bananas. I have a steady 2 bars of 4G and the mobile radio is constantly active.
    11-21-2015 09:07 PM
  12. qonic's Avatar
    What is this talk about radio? D2 has a radio like the phone before the bionic.
    11-21-2015 10:56 PM
  13. Masheen's Avatar
    *Fixed* after experimenting with turning off a ton of settings one by one, I found the way to stop cell standby drain when in lower reception areas.
    Set location to battery saving from high accuracy. (Battery saving is actually the default setting on a new DT2)
    11-22-2015 01:12 AM
  14. bogeyjoker's Avatar
    I was having the same (or similar) problem. Phone reception in my house is 1x or 3g half the time. Phone was also awake 100% of the time. I'm not sure the issues were related, but I did a factory reset and only installed my most important apps and did them one at a time to see if I could isolate if it was a rogue app or if it was systemic.
    I'm not sure what the culprit was, but so far so good. Phone is awake only when I want it awake...but phone radio is still lousy inside my house.
    11-22-2015 06:40 AM
  15. Masheen's Avatar
    When you use turn by turn nav on maps it prompts you to switch to high accuracy location setting. So that factory reset very well could have just put your location setting back to battery saving, which is the default at first time startup, that is, if you were having the cell standby issue.
    11-22-2015 12:45 PM
  16. bogeyjoker's Avatar
    Mine is and was set on "Device only".
    11-23-2015 05:27 PM
  17. viper8315's Avatar
    So, my phone is being held awake 100% of the time as well. Anybody have suggestions? I've already disabled most of the apps, are they any known culprits that come pre-installed?
    11-24-2015 09:47 AM
  18. Masheen's Avatar
    That looks like a renegade app. Can you post a SS from Process Stats in developer menu please, and cross reference that with stock battery monitor and GSam battery monitor.
    11-24-2015 02:59 PM
  19. bogeyjoker's Avatar
    Yep...that looks very familiar...except your network signal looks better than mine ever does.
    11-24-2015 03:22 PM
  20. viper8315's Avatar
    Any ideas which one?
    Battery Drain Issues &  Resolutions-screenshot_2015-11-24-21-24-53.jpgBattery Drain Issues &  Resolutions-screenshot_2015-11-24-21-25-01.jpgBattery Drain Issues &  Resolutions-screenshot_2015-11-24-21-25-08.jpgBattery Drain Issues &  Resolutions-screenshot_2015-11-24-21-25-14.jpgBattery Drain Issues &  Resolutions-screenshot_2015-11-24-21-25-20.jpgBattery Drain Issues &  Resolutions-screenshot_2015-11-24-21-25-25.jpg
    11-24-2015 08:30 PM
  21. viper8315's Avatar
    So you never found what app did it? You just did an FDR, and chose not to auto-install your apps?
    11-24-2015 08:33 PM
  22. Masheen's Avatar
    Check We Chat how often it's pushing, also check GSam battery monitor and the stock and see if there's a similarity to what pro stats shows. Also hit the hamburger menu in pro stays and change duration to 12hrs or 1 day and see if that changes anything. Based on those stats, it doesn't show what the culprit is.
    11-24-2015 09:28 PM
  23. viper8315's Avatar
    Just did an FDR....I'll slowly put apps back on.
    11-24-2015 09:48 PM
  24. bogeyjoker's Avatar
    No...never did. And yes, I just did the reset and added apps back. I've got everything that I want back and now I'm fine. I'm at 51 hours with 32% left.
    11-26-2015 06:54 AM
  25. 1901Madison's Avatar
    Anyone coming from the original Turbo notice that with the screen on, the Turbo 2 drains significantly faster than the original Turbo? Sadly, the difference is significant.
    11-26-2015 12:12 PM
61 123
  1. What is this showing on my battery usage?
    By Marto1985 in forum Android 6.0 Marshmallow
    Last Post: 11-27-2015, 10:05 PM
  2. Factory Reset for better Battery!
    By 1dtbrown in forum Samsung Galaxy S6 edge
    Last Post: 11-21-2015, 06:37 PM
  3. Why am I getting battery over temperature messages?
    Last Post: 11-20-2015, 04:47 PM
  4. Nexus 6p headphone jack issue
    By Fiasco62 in forum Nexus 6P
    Last Post: 11-20-2015, 11:50 AM
