Save big + get 3 months free! Sign up for ExpressVPN today
07-30-2016 05:34 PM
280 ... 34567 ...
tools
  1. weatherlover1's Avatar
    I have widgets yes. But both my weather widgets are set for hours for updates one is 8 the other is 24. I have Google Calendar and tweet caster but tweet caster is set for 2hr updates. I also have a Google now widget.
    12-05-2015 06:30 PM
  2. weatherlover1's Avatar
    I also use go launcher z but I can't believe a launcher is the problem.
    12-05-2015 06:33 PM
  3. weatherlover1's Avatar
    I am going to have to plug my phone in.. Here is today's usage. Thank you to everyone who has offered advice I'm getting close to trying a factory reset to see if that will help. Sigh..
    DROID Turbo 2 Battery life-uploadfromtaptalk1449362254017.jpgDROID Turbo 2 Battery life-uploadfromtaptalk1449362279236.jpgDROID Turbo 2 Battery life-uploadfromtaptalk1449362292527.jpgDROID Turbo 2 Battery life-uploadfromtaptalk1449362306690.jpg
    12-05-2015 06:39 PM
  4. beeare's Avatar
ID:	208622Click image for larger version.
ID:	208623Click image for larger version.
ID:	208624Click image for larger version.
    Yeah your awake time is nuts. Clearly something is waking the phone constantly. Here's where I'm at today...
    12-05-2015 07:23 PM
  5. doogald's Avatar
    I suppose it could be.
    I can't remember if you've mentioned it - Have you tried a wipe of the cache partition yet?
    12-05-2015 07:29 PM
  6. weatherlover1's Avatar
    Yes I did do that. I am also switching over to Nova.
    12-05-2015 07:30 PM
  7. tpence2177's Avatar
    Pretty happy with mine so far after a week . This is my light usage over the weekend. I usually have to charge every night during the week to keep from having to charge during the day. DROID Turbo 2 Battery life-uploadfromtaptalk1449413687281.jpgDROID Turbo 2 Battery life-uploadfromtaptalk1449413707948.jpg
    12-06-2015 08:55 AM
  8. 18t's Avatar
    I experimented last night. The one time I didn't charge overnight, I lost 4-5% while sleeping. I setup a tasker profile to turn off auto sync over night - BAM, less than 1% lost.
    12-06-2015 09:18 AM
  9. beeare's Avatar
    Figured I'd test this without charging overnight. It was about 30% when I went to sleep. I'd normally charge if this were the case, but I wanted to test the battery a little. I'm very content with these #'s. I was on whatsapp a ridiculous amount yesterday and this is usually a battery killer, so 5hr plus screen time considering that is impressive my opinion.
    12-06-2015 11:48 AM
  10. weatherlover1's Avatar
    Well my battery is doing better. I believe my go launcher was the problem. I deleted it and went with nova. I still am not getting as good of sot as I would like but my phone has been off the charger since 6am and its 11pm and I'm at 39% so much better. If people are getting crappy battery its an app. Your stats may not tell you much it becomes a bit if a guessing game to find the power sucking culprit but it can be done.
    DROID Turbo 2 Battery life-uploadfromtaptalk1449547306928.jpgDROID Turbo 2 Battery life-uploadfromtaptalk1449547315701.jpg
    12-07-2015 10:02 PM
  11. bogeyjoker's Avatar
    Keep working at it...it should get much better than that. You still have a wake issue. I plugged my phone in last night after 61 or 62 hours of use with similar SOT as yours (~2 hours/day). The first 10 hours of that, I was hunting and virtually no cell signal, so it drained quite precipitously during that time.
    12-08-2015 06:30 AM
  12. weatherlover1's Avatar
    Thanks! Yeah i know something is still keeping it awake not sure what. Maybe Google fit. I'm just happy to get a day out if it. It does also seem to be getting better each day.
    12-08-2015 06:35 AM
  13. xocomaox's Avatar
    You seem to be the only person in this thread that actually has good numbers.
    weatherlover1 likes this.
    12-08-2015 03:51 PM
  14. 18t's Avatar
    The sad part is that it looks like the moto x play gets better average battery life. Common reports of 5-6 SOT in a day. Some up to 7-8 hours.
    12-08-2015 04:54 PM
  15. beeare's Avatar
    That would kind of make sense given the lower resolution screen on the x play. And a lot of people seem to feel the screen is what hits the Turbo2 especially hard. It does seem like that sometimes, but by the end of my cycle, when I check my stats before bed, they just end up pretty good. Do a lot of the people who are experiencing bad SOT play a lot of games? I don't play any games really. Games always seem to crush battery, so wondering if that could be part of the issue.
    12-08-2015 05:35 PM
  16. weatherlover1's Avatar
    I don't play any games. I use it for facebook email etc. Today is better I'm at 59% and have been off charger sense 6a but very little screen time really. Something is still keeping it awake I can't believe its facebook but maybe. I am using a screen dimmer app and my battery still seems to go down pretty fast. But it's much better then a week ago when I got it. I feel like I trust it to get me through a day now but I would be happier if u can get over 3hrs sot. I don't think I can yet but have not had time to test it. I have only had 38 minutes of screen time but my phone has been awake for over 3.
    12-08-2015 05:43 PM
  17. leehardballer12's Avatar
    From my experience on the first DT, screen brightness is a huge factor in how long the battery lasts. Personally, if I have the brightness set at higher than 50%, I have problems lasting through the day. If I keep it around 25%, I can get through the day and into the next day, assuming I'm not on the phone with the screen on. I always have the adaptive brightness on. When I watch video, I turn the brightness way up to about 75%. I didn't get a phone with this nice of a screen to have it dimmed way down so I can't enjoy it. On the other hand, I don't need the brightness turned up for doing everyday stuff like messaging, fb, and web browsing wasting the battery.
    12-08-2015 05:56 PM
  18. beeare's Avatar
    I'm the exact same way, but keep my screen at about 40%.
    12-08-2015 06:10 PM
  19. xocomaox's Avatar
    I personally feel like there are software configuration issues going on with the Turbo 2 and that it should get numbers similar to the X Play. The biggest factor, hardware-wise, isn't the screen. It's the SoC. SD810 vs SD615 is a huge difference in power draw. The resolution isn't going to affect it too much in normal usage, honestly.
    12-09-2015 07:53 AM
  20. weatherlover1's Avatar
    So after more investigation I think I have my battery issues fixed. It's 3:15 pm and I have 73% battery life left. My advice to those who are still not getting great stats. Disable Verizon bloat. I disabled Verizon cloud and security and that seemed to really help I had gotten rid of the other stuff earlier. I also have google fit for syncing data from my polar watch. I kept google fit but turned off the tracking. I might try turning it back on to test after a few days. I agree with the above poster I think there are some software issues between Verizon's crap and moto. I still need to see how much sot I can get. My battery would be even better today but I was in a restaurant for lunch and it had bad signal and my phone worked hard for an hour, but that happens. I am happier and happier with this phone. I just don't think Verizon's and moto's software is playing nicely together.
    xocomaox likes this.
    12-09-2015 02:24 PM
  21. doogald's Avatar
    The Verizon bloatware issue is a crime. They charge high end dollars for this phone and they still have to get subsidies from the bloatware makers? Ridiculous.
    12-09-2015 04:20 PM
  22. NickB2005's Avatar
    So my Turbo is getting eh battery life. I took it off the charger at 730am this morning and it's 130pm and I am at 75%. I don't think it's that great, but what apps can I disable that is bloat that would help me?
    12-15-2015 12:30 PM
  23. weatherlover1's Avatar
    Start with Verizon apps. I deleted all games and then disabled the cloud and security and whatever else I don't use. I also disabled Dt light or I think that was the name. My phone was off charger at 6:15 this morning at at 1:30 its at 81%. I have not used it a ton though. I am not impressed with sot so far but I have not tested it completely. I would also check the update times of any apps such as weather or Twitter. The more often they update the more your phone is awake.
    NickB2005 likes this.
    12-15-2015 12:34 PM
  24. 18t's Avatar
    DT Ignite. It's a backdoor for Verizon to install apps without your permission, and will reinstall them if you remove them while not disableing DT Ignite.
    12-15-2015 02:01 PM
  25. weatherlover1's Avatar
    Ignite! I knew I was close. Yes I looked it up when I saw it in my app use list I was happy to disable it.
    12-15-2015 02:03 PM
280 ... 34567 ...
  1. Why won't my battery last 2 hours?
    By Reaper 3-9 in forum Hardware Hideaway
    Last Post: 12-03-2015, 09:25 AM
  2. Where can I buy a sim or TF Card for Droid Model M729S?
    By Nona Noble in forum General Help and How To
    Last Post: 12-01-2015, 02:59 PM
  3. Why is the battery on my Samsung Galaxy S3 dying so fast?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 12-01-2015, 11:27 AM
  4. Why does my phone show a yellow triangle and a battery dead signal?
    Last Post: 12-01-2015, 11:26 AM
  5. Replies: 1
    Last Post: 12-01-2015, 07:04 AM
