Weatherlover-
I switched to adaptive brightness and toggled to around 50% brightness and I've noticed a lot better battery life. I'm sure you're aware of it but just a suggestion if you don't have it enabled. Up to 6 hours sot now.
I disagree. It's been shown that 5 hours SOT is very possible, as is more. My G3 struggles to get to 4 hours, and is usually dead by 3.5. I had to charge the G3 at work nearly every day. With the DT2 I go to bed with 30% remaining.
The G3 should get 5 hours.
I figured the Droid Turbo 2 would get 6+ consistently, but going by all the numbers in this thread that does not seem to be the case. It looks like a combination of poor SoC power usage, wakelock/alarm issues, and radio drain.
The G3 should get 5 hours or it does get 5 hours? I'm actually just curious to know if the G3 has the reputation for getting up to 5 hours regularly over a full day. Most phones can get 5 hours if you pull them off the charger at 100% and then run it down over the course of a short day, and then need to charge again in the afternoon. The difference is this phone can get 5 hours and last you 24 hours on a single charge. That's been my experience with it at least. I can clearly see that many other people aren't getting #'s that good. I'm not sure if the battery settling in theory really holds any merit, but my phone has definitely improved over 2 weeks. I wasn't getting that type of battery life right off the bat, but I attributed it more to abnormal use due to tweaks in settings, downloading apps, etc., which tapers off as things become the way you'll eventually leave them.
Based upon others feedback, my experience seems to be more common than his.
http://forums.androidcentral.com/showthread.php?t=588826
You're certainly not the only one, I just restarted my phone and lost 6%!!! Not going to get even 18 hours out of mine today. Frustrating.I don't mean to post so much just trying to figure out why my phone is getting such bad battery life. Those that are getting good battery results are you using moto assit or any of the features? I turned moto assit on because it was part of the reason I got the phone and they talked about how it uses less processer power or something. So was curous those who are getting good sot what moto features do you have turned on? Thanks!
Can't do anything about the signal live in an area with low signal. I cleared my app cache I also reset the cache in recovery mode. I think it helped. Otherwise I will do a factory reset. Ugh..Look at your awake time in post #52...your phone is awake nearly all the time. It's not as bad as mine was before my factory reset, but still pretty bad. Something (I'm guessing a rogue app) is keeping your phone awake and your battery is suffering. Your network signal is also a bit sketchy for a fair amount of the day.
I feel your pain. I'm trying to wait for Marshmallow before factory data reset!Can't do anything about the signal live in an area with low signal. I cleared my app cache I also reset the cache in recovery mode. I think it helped. Otherwise I will do a factory reset. Ugh..
Here is how it looks after clearing the cache and charging it to 100%. I used it for almost a hour to see how the battery did. It does not seem to be dropping as fast. I also have the app doze on it to help with background apps but not sure how well its working. I really did not expect this much trouble. I swear every Motorola phone I have had gives me issues. My note 3 was pretty good to me. O well.I feel your pain. I'm trying to wait for Marshmallow before factory data reset!
