doogald
Trusted Member
Re: 48 hr battery my " you know what!"
But held awake is only using 2% of the battery, according to GSAM.
Obviously the display on this phone is a terrible draw of battery.
To the OP: do you use advanced calling/VoLTE for calls? I wonder if you turned that off and used CDMA calling if you'd get better battery life? The 47 minutes of calls used a lot of battery as well.
To be honest, though, at this point Android just lacks good tools to diagnose battery usage like this (at least unless you are rooted). GSAM and the Android battery usage can give you clues, but not real answers. Without breaking down "Android OS" and "Android System" you just can't do anything but guess at the cause.
Also, the OP has some wakelocks.
