1. 18t's Avatar
    So I wasn’t quite convinced that this phone would make it through a 2 day period. This after my d.maxx would routinely do it. For the few others that have, post your stats in here. I’m curious of your setup and SOT. Sorry if the pics come out huge.
    For the record:
    • I had somewhat limited my use of the device. I only used it when I really needed to.
    • I had the screen dimmed almost completely for about 80% of the time.
    • I did make a few short calls.
    • I did watch some youtube
    • I did stream a little music.
    • I used tasker to disable sync overnight.
    For comparison sake from my d.maxx – notice the SOT and 35% battery remaining, although not quite 48 hrs.
    And from my first 48 hour run on DT2. I probably could have hit 4.5 SOT hours and 50 something, but I try not to let my battery get that low.
    weatherlover1 likes this.
    12-09-2015 08:41 AM
  2. weatherlover1's Avatar
    Very nice. Curious if you know the held awake time. That seems to be a big factor in the battery life.
    12-09-2015 08:54 AM
  3. 18t's Avatar
    I do not. I was using gsam but one time it read a different SOT than the OS stats and I didn't like it running in background.
    Doze in 6.0 should help alot with awake times. Hopefully it will make this phone what it should have been.
    12-09-2015 09:43 AM
  4. bogeyjoker's Avatar
    Very similar to what I'm seeing 18t. I keep forgetting to grab a screenshot before I plug in. GPS, Wifi, and SOT time all look comparable to mine. Your network signal is waaaaay better than mine. I'm yellow or orange about 90% of the time. Also your awake time is a bit heavier than mine.
    I had the same experience with GSAM...IMO a battery monitor shouldn't be a resource hog. I've been running Doze on my phone and, it may a coincidence, but my awake time seems worse with it....
    12-09-2015 12:39 PM
  5. 18t's Avatar
    As long as you aren't plugged in for long your stats should still tell the story. Network signal makes a big difference!
    12-09-2015 01:55 PM
  1. Replies: 1
    Last Post: 12-09-2015, 03:04 PM
  2. Replies: 2
    Last Post: 12-09-2015, 08:59 AM
  3. Replies: 0
    Last Post: 12-09-2015, 08:30 AM
  4. Replies: 1
    Last Post: 12-09-2015, 08:10 AM
