1. AC Question's Avatar
    Im have pretty low volume on the new Turbo 2. The earpiece is only hearable when flush against the ear, unlike almost every other phone where i can have it an inch or so away and still hear everything.
    Ive turned on HD voice and turned off private calls (whatever that thing is called which says it encrypts voice calls).
    I also did a hard reset.
    Anyone else disappointed with the sound quality for phone calls?
    12-09-2015 12:57 PM
  2. perkdog65's Avatar
    I have no issue with the volume it is plenty loud to me, but I usually hold it to my ear when I talk, unless I have it on speaker.
    12-09-2015 04:17 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Is the volume on speakerphone and on wired or Bluetooth headsets fine? Does it look like there's any debris lodged in the earpiece speaker grille?
    12-09-2015 04:35 PM
  4. copywrite's Avatar
    You can disable the audio effects to see if that helps. Otherwise you may want to swap it out for a new one, or try another in the verizon store to see if it's louder for you. I have no problem with the volume and haven't read of to many people who have.
    12-09-2015 04:50 PM
  1. Replies: 10
    Last Post: 02-18-2017, 10:17 PM
  2. Note 4 just flashes on and off, on and off.
    By Tinagg in forum General Help and How To
    Last Post: 12-09-2015, 04:00 PM
  3. Replies: 3
    Last Post: 12-09-2015, 02:01 PM
  4. Replies: 1
    Last Post: 12-09-2015, 01:02 PM
  5. Auto-correct woes with emails and languages, can I get some help?
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 12-09-2015, 12:25 PM
