1. AC Question's Avatar
    How do I scan a business card with my DROID TURBO 2 phone?
    12-30-2015 07:49 AM
  2. dpham00's Avatar
    Mod Note, I will move this to the t2 forums for more visibility
    12-30-2015 07:59 AM
  3. cbironman24's Avatar
    You could scan it in Google Drive.
    12-30-2015 10:32 AM
  4. djseishin's Avatar
    Love this feature. Just hold the biz card in front of the camera. Let it focus on it, but don't click to take a picture. After a couple seconds it will recognize it and a little pop-up will give you the option to add to contacts.
    kmf1 and jonstrong like this.
    01-06-2016 11:04 PM
  5. PowrDroid's Avatar
    Surely this is a non-Motorola app and not included with the phone's software?
    01-07-2016 10:02 AM
  6. Soundtallica's Avatar
    No, it's included in the phone's software as it's baked into the camera app. You don't activate it from the settings, the camera automatically detects if there's text in a business card format and gives you the popup when it senses it. It's actually been very reliable for me.
    jonstrong and djseishin like this.
    01-10-2016 11:35 PM
  7. PowrDroid's Avatar
    Do you hold the phone in landscape mode or portrait? How long does it take for the phone to "sense" the business card?
    01-11-2016 01:24 PM
  8. Hgouck's Avatar
    You can hold it in either position. Takes about 5 second and a green icon will appear between the front/back icon and the video icon. Just tap it and there you go
    01-11-2016 06:42 PM
  9. Feldhege's Avatar
    Works for barcodes and QR codes too!
    01-12-2016 02:56 PM
  10. Gwendolyn Cherry-Simms's Avatar
    05-13-2016 11:06 AM
  11. jkn1946's Avatar
    As above, activate the camera, place card so you can see it in the screen, and hold....in a few seconds a green dot will appear, touch it and you will see the contact info and given a choice of what contact database to use (cloud, outlook, etc)
    Good Luck
    jonstrong likes this.
    05-13-2016 11:25 AM
  1. Wifi not working on Galaxy Grand Prime.
    By Sabali in forum Ask a Question
    Last Post: 01-19-2016, 01:04 AM
  2. Replies: 1
    Last Post: 12-30-2015, 07:48 AM
  3. How can I fix a Samsung Note 4 Camera problem?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 12-30-2015, 07:12 AM
