1. THEPRFCT10's Avatar
    Ok, so I noticed that when I get a phone call or notification, the volume is significantly lower than what I have set. If I have full volume set, the actual sound comes out about half that. Now if I go into settings to "test" the sound, it goes at the selected volume, like FULL. Annoying because when phone is in my pocket, I can barely hear it. I soft reset but no luck.
    01-08-2016 12:41 PM
  2. Rukbat's Avatar
    When you're not on a call, the volume rockers are for the ringtone. When you're on a call they're for the phone volume. (When you're playing music, they're for media.) There are separate levels, and you have to set the correct one. Turning up the volume during a call won't turn up the ringer volume. (There's also a "Increase volume in pocket" checkbox in Device/Call. That uses the proximity detector to increase the ringtone if the front of the phone is against your leg (or other body part).
    01-08-2016 05:31 PM
  3. copywrite's Avatar
    Never seen the "increase volume in pocket" option before. Where is it located?
    01-08-2016 06:19 PM
  4. doogald's Avatar
    I believe that when you are connected to Bluetooth there is even another separate Bluetooth media volume that's different from the speaker/headphone media volume, too.
    01-08-2016 09:27 PM
  5. THEPRFCT10's Avatar
    I don't have that option on the phone. My Samsung Galaxy S4 did and I used it and it worked well. I'm aware of the three different settings, however that's not my issue. Mine is I have ringtone volume set to full blast. When testing or setting it, it's nice and loud. When my phone actually rings, the volume is about half that.
    01-09-2016 06:57 AM
  6. doogald's Avatar
    This was (is?) a problem with the Turbo as well.
    Volume turning itself down?
    http://forums.androidcentral.com/sho...d.php?t=462927
    You can read through that thread and see if any of the suggestions help (eg, if you use moto assist for drive mode or to turn off the sound overnight, try turning those options off and see of it still happens; if you use headphones or bt, see if it happens only after you've connected those to the phone after a restart.)
    That thread didn't seem to definitively suggest a solution.
    01-09-2016 07:25 AM
  7. THEPRFCT10's Avatar
    Will do thanks!
    01-09-2016 07:28 AM
  8. doogald's Avatar
    Here is another thread in the Turbo forum: http://forums.androidcentral.com/mot...oid-turbo.html
    And another in another forum: http://www.droidforums.net/threads/r...pocket.277250/
    I knew that I'd read about that problem. I honestly never saw anybody post a known solution. Good luck; I hope that you figure it out.
    01-09-2016 11:43 AM
  9. THEPRFCT10's Avatar
    It's very frustrating, thanks!
    01-10-2016 11:35 AM
  1. Why is my S5 the best phone I've yet owned?
    By scrondar in forum Samsung Galaxy S5
    Last Post: 01-12-2016, 07:24 AM
  2. Why is my phone taking some long to update!
    Last Post: 01-08-2016, 03:05 PM
  3. Why is my phone displaying no sim no service?
    By AC Question in forum Moto E (2014)
    Last Post: 01-08-2016, 12:48 PM
  4. why my android is not able to activate line account?
    Last Post: 01-08-2016, 11:41 AM
  5. My Galaxy Note 3 is suddenly losing battery life quickly.
    Last Post: 01-08-2016, 11:37 AM
