1. AC Question's Avatar
    Do any of you guys know if a Samsung wireless charger would work fine with a Moto DT2 (Moto x Force here in the UK). I'm assuming it would it's I'm a bit concerned about buying a cheap (I'm guessing Chinese)one from Ebay. Concerned about overheating issues.
    02-08-2016 06:21 AM
  2. the tall guy's Avatar
    Hi, yeah I don't see why it wouldn't work, it's just a Qi charger. I've charged my Nexus 7 on my Samsung wireless charger pad before (was very slow, but it charged)
  3. the tall guy's Avatar
    02-08-2016 06:55 AM
  4. jimbo1mcm's Avatar
    I have a Samsung wireless charger and the D2 works on it. The charging receptor inside the D2 is slightly lower than center, so you have to adjust for it. I use a 3 coil charger that is available on ebay and sits at about a 45 degree angle. I had to put a pencil on the bottom to raise up the D2 to accomodate the centered coils. After that it works just fine. Very convenient.
    the tall guy likes this.
    02-10-2016 02:07 AM
  5. wyseguy77's Avatar
    Does it fast charge?
    02-10-2016 10:53 PM
  6. Jaingo5150's Avatar
    It will not fast charge on any wireless charger. Only the note 5 and edge 6+ will fast charge on this.
    02-11-2016 11:13 AM
  7. Michael_French_RN's Avatar
    I think most of the Wireless Qi chargers on the market only charge at 5 watts, as opposed to the 25 watt fast charge from the OEM charger with the DT2. This was info I found on the Wireless Qi Consortium's web page. They were talking about a next generation Qi charger they are testing that might do 15 watts.
    Doc
    Posted via the Android Central App on my Motorola Droid Turbo 2
    02-12-2016 04:55 PM
  1. Replies: 3
    Last Post: 03-04-2016, 07:44 AM
  2. Replies: 2
    Last Post: 02-10-2016, 01:06 PM
  3. Replies: 1
    Last Post: 02-08-2016, 02:24 AM
  4. How can I change my default printer to PDF on my Droid Turbo?
    Last Post: 02-07-2016, 01:50 PM
  5. Not able to Factory reset moto g (3rd Gen)
    Last Post: 02-07-2016, 11:48 AM
