1. THEPRFCT10's Avatar
    Can someone please explain to me why and how just after I unplug my phone, it's telling me I'll have only 4 hours of use?! This is getting ridiculous!Battery life deteriorating-uploadfromtaptalk1455456515947.jpg
    02-14-2016 08:28 AM
  2. 1901Madison's Avatar
    Did you let it charge to 100? How long did it take to go from 100 to 96?
    02-14-2016 08:31 AM
  3. THEPRFCT10's Avatar
    Yes. It took about 10 minutes! Unreal!
    02-14-2016 09:12 AM
  4. Robert Beier's Avatar
    That's not even close to typical. You either have a bad device or an app that is draining your phone. What steps have you taken as far as trouble shooting?
    02-14-2016 11:59 AM
  5. THEPRFCT10's Avatar
    I'm looking at GSAM, battery stats, recovered in SAFE mode but no luck
    02-14-2016 12:01 PM
  6. flyblockgame's Avatar
    Thats weird
    02-14-2016 12:16 PM
  7. doogald's Avatar
    I know you've posted several battery threads and posts, and I don't want to look for them all, but have you:
    1. Do you use wireless charging? If yes, do you get different results if you use the stock turbo charger exclusively for charging (i.e., no plugging in in the car, no wireless charging, no using any other charger/cable)?
    2. If that's not it, let the phone drain without plugging in until it asks to shut down and then plug in without unplugging until it reaches 100%; does that change anything?
    3. If it's not wireless charging or resetting the charge circuitry with number 2, have you backed up all of your photos, videos and contacts (if you don't sync them) and done a factory data reset?
    If yes, I'd strongly consider contacting Motorola and asking for a warranty replacement.
    02-14-2016 12:24 PM
  8. THEPRFCT10's Avatar
    Thanks for the advice I really appreciate it. I've never wirelessly charged. I'll try step two today. Will let you know and thanks again for all your help
    02-14-2016 12:37 PM
  9. beeare's Avatar
    Your screen was on the whole 10 minutes right? Losing 4% with the screen on for minutes straight isn't totally surprising. Depends on the brightness too. At that point the 4 hours remaining would be extrapolated based on just those 10 minutes where the screen was on the whole time. You should be able to get more than 4 hours SOT so it's not good, but I don't think it's quite as bad as you're making it out to be.
    What were you doing for those 10 min? Also if you haven't cleared the cache for a long time and rebooted, I would do that first.
    SandersJC1964 likes this.
    02-14-2016 06:41 PM
  10. THEPRFCT10's Avatar
    Ok cool thanks. During that time just Chrome, Tapatalk.
    02-14-2016 07:38 PM
  11. SandersJC1964's Avatar
    Just what beeare said. That graph is based on your current usage. Set it down a while and it'll change.
    02-15-2016 09:42 AM
  1. S4 Battery Drains Fast
    By Glowsticks in forum Samsung Galaxy S4
    Last Post: 02-18-2016, 02:38 AM
  2. battery issue?
    By Jake12121 in forum Moto X Play
    Last Post: 02-16-2016, 11:08 AM
  3. Bluetooth headphone battery app
    By maverick7526 in forum Nexus 6P
    Last Post: 02-14-2016, 05:27 PM
  4. battery's hot whrn charging until battery's fully charged.
    Last Post: 02-14-2016, 08:54 AM
  5. Replies: 1
    Last Post: 02-13-2016, 10:09 PM
