1. Demoic's Avatar
    Wasn't sure whether this is below average battery life or to be expected. I attached some of the battery screenshots.
    Attached Thumbnails Below Average Battery Life-screenshot_2016-03-02-21-41-35.jpg   Below Average Battery Life-screenshot_2016-03-02-21-41-49.jpg   Below Average Battery Life-screenshot_2016-03-02-21-41-59.jpg   Below Average Battery Life-screenshot_2016-03-02-21-42-13.jpg   Below Average Battery Life-screenshot_2016-03-02-21-42-25.jpg
    03-03-2016 07:15 AM
  2. Javier P's Avatar
    Your battery stats show a couple of things.
    - Frequent weak cell signal. This will drain the battery, specially while using 4G, as you status bar shows.
    - Your awake bar is almost solid. You need to check which processes are running almost non stop in the background. Take a look at your sync/upload settings.
    03-03-2016 07:27 AM
  3. Demoic's Avatar
    Where is the sync/upload settings? Are you talking just email as I believe they are push to phone for updates. Will those short periods of lower signal really drain it that fast? It looks green more than half the time with very little red.
    03-03-2016 07:37 AM
  4. Javier P's Avatar
    I mean in apps like Photos, Play Store, news readers, etc. Try to sync/upload/update while on WiFi, for example, or if possible when charging. Also check the sync frequency in your widgets or social apps. As you can see in your graph your phone is awake for a long time. Quite difficult to be sure why.
    03-03-2016 08:06 AM
  5. Demoic's Avatar
    So just go into the apps and check the settings for updates\notifications? If so is there any other easier way or some in particular I should start looking or a way to tell where to look.
    03-03-2016 09:29 AM
  1. Replies: 1
    Last Post: 03-03-2016, 12:43 PM
  2. Weird battery problem
    By gtt1 in forum ASUS ZenFone 2
    Last Post: 03-03-2016, 10:12 AM
  3. battery
    By Jaiswalpratik in forum Moto X Play
    Last Post: 03-03-2016, 04:32 AM
  4. battery draining
  5. Why does my A8 battery drain overnight?
    Last Post: 03-02-2016, 11:03 PM
