1. dannyro77's Avatar
    Just wondering if anyone else is having sound issues with Marshmallow....updated today, and noticed that text messages are coming through but when the screen is off, the first text has an abbreviated sound and the second text is completely silent. Anyone else noticed this or can anyone recommend a fix? I did restart the phone after the update...no change. I don't want to factory reset-I'd use that as a last resort. Im using a notification tone from Zedge-not sure if that matters.
    Any help is appreciated.
    Dan
    03-11-2016 08:27 AM
  2. THEPRFCT10's Avatar
    Same issue here!
    03-11-2016 10:47 AM
  3. Pollster's Avatar
    Dan
    Same issue here!
    Which app do you folks use to text?
    03-11-2016 12:27 PM
  4. dannyro77's Avatar
    I use the Verizon + message app
    03-11-2016 01:04 PM
  5. tlacour's Avatar
    I go back and forth between Textra and the Verizon Message+ app. They both work flawlessly. Textra seems more polished and smoother. Message+ has some better features and can be used across other platforms.
    03-11-2016 01:34 PM
  6. Toes Up's Avatar
    Oddly enough, I am going back and forth between the two as well. I have not noticed any problems with Message +, but I am using the stock ring tone. I would uninstall the app, then reinstall it. That worked for me on another misbehaving app after the update.
    03-11-2016 02:00 PM
  7. copywrite's Avatar
    There seems to be a bug with the volume settings in marshmallow. Sometimes they volumes will seem lower than their setting. Overall, the only change is that call volume has a higher max (8 steps instead of 7). Try safe mode and see if your volume is normal again. My notification volume will sometimes seem lower than the setting, but the next day it will be fine.
    03-11-2016 03:05 PM
  8. dannyro77's Avatar
    After the first text, my phone is completely silent. I guess I will try to get into safe mode and see if it is normal again. If it is, what can I do to fix it?
    03-14-2016 07:44 AM
  9. THEPRFCT10's Avatar
    Textra for me. Still having sound issues including muted volume and no sound on YouTube. Factory data reset looks inevitable
    03-14-2016 09:26 AM
  10. perkdog65's Avatar
    I had the same problem with the Message+ so I DISABLED the setting "Enable Pop Up over lock screen" and it seems to work now like it used to. Hope it helps.
    03-14-2016 09:53 AM
  11. dannyro77's Avatar
    cool that sounds like an "app" issue and not a MM issue-hopefully Verizon has a fix for that app releasing soon? Although the poster above said he was having issues with Textra as well. I have not experienced any sound issues with YouTube though.
    03-14-2016 10:25 AM
  12. dannyro77's Avatar
    thanks perkdog that worked for me as well. So weird. You can keep "enable popup" checked and it works but sure enough it you check "enable popup over lock screen" no sound!
    Nice detective work. I can live without the popup over lock screen to once again hear the texts. thanks again.
    perkdog65 likes this.
    03-14-2016 10:43 AM
  13. perkdog65's Avatar
    Glad it worked for you as well.
    03-14-2016 02:19 PM
  14. GD TAYLOR's Avatar
    10.21.16 purchased pixel lx at full retail price. out of box sound issues? what the hell,this is BS
    10-22-2016 07:43 AM
  15. JohnCer's Avatar
    The wife has been having the same issue with her DT2. Just disabled popop over locked screen and seems normal now. Thanks for the info. ☺
    12-13-2016 09:07 AM
  1. Updated to Marshmallow last night and Waze no longer works
    By mcoomer in forum Samsung Galaxy Note 5
    Last Post: 06-11-2016, 11:34 PM
  2. Has anyone figured out the over saturation while playing games issue?
    By AlphaVictor87 in forum Samsung Galaxy S7 edge
    Last Post: 03-11-2016, 10:04 AM
  3. Replies: 1
    Last Post: 03-11-2016, 09:15 AM
  4. Replies: 1
    Last Post: 03-11-2016, 08:28 AM
  5. Are the SkullCandy s2rfda -003 earphones compatible with the Moto E?
    Last Post: 03-11-2016, 07:49 AM
