1. xdollface8's Avatar
    How are you cleaning your clear cases? Mine gets a little dirty sometimes. A simple wipe leaves it with streaks or clouds.
    03-18-2016 09:03 PM
  2. Zarin Rahman's Avatar
    Use a Toothbrush to Clean Your Case. To remove mild stains, dust, and grime from your silicone case, use warm water, dish soap, and a toothbrush. If you have only mild stains or your case is dirty with dust and grime, then all it needs is a good wash. Grab a small bowl and fill it with warm water and dish soap
    Laura Knotek and xdollface8 like this.
    03-19-2016 01:01 AM
  3. xdollface8's Avatar
    Thanks!
    03-20-2016 12:13 PM
  1. Good looking case?
    By lita_g in forum Nexus 6P Accessories
    Last Post: 05-07-2016, 08:53 PM
  2. Is there a Wireless charging compatible case?
    Last Post: 04-03-2016, 08:09 AM
  3. Clear Case with Portrait View Kickstand?
    By recDNA in forum Samsung Galaxy S7 edge Cases & Accessories
    Last Post: 03-20-2016, 02:31 PM
  4. Replies: 4
    Last Post: 03-18-2016, 02:22 PM
  5. Blu Advance 5.0 case options?
    Last Post: 03-17-2016, 11:16 PM
