08-02-2016 09:45 AM
44 12
tools
  1. Moo Cow's Avatar
    It's not in the Wi-Fi area. You have to go to Settings>Location then hit the 3 dots in the upper right. That will reveal "Scanning" and then the Wi-Fi and Bluetooth scanning.
    In the short time since my last post and doing this, yes, my WiFi option was on but not Bluetooth. Turned WiFi off. The green bar has halted.
    Battery power still draining quite a bit but im using the phone a bit more today fixing this issue, so I can't give an improvement status. Once I resume work and put the phone down, I will see how the battery power reflects. Hopefully this is a simple fix.
    Still looking for a good WiFi auto on app. Disappointed the other one no longer wants to work. I might just email the maker as I intended. I loved how it turned on and off automatically and now it doesn't. Because again, I turn stuff off I am not using and turn it on when I am, and WiFi is one such thing. Sounds silly to some that I'm worried about this when I have a large battery, but just throw me a bone and overlook it. (I'm the pickles McDonald's threw on your hamburger when you specifically requested it plain, lol.)
    Otherwise, as long as the aforementioned fix does solve my WiFi issue, the DT2 is like the DT1 for me and I'm satisfied.
    06-10-2016 01:39 PM
  2. Moo Cow's Avatar
    Wi-Fi Matic is "broken" for DT2 Marshmallow and I sent an email to the maker to explain. Wi-Fi is not turning off, and believe it or not, it is a HUGE battery drainer to have Wi-Fi on where I don't need it. I've tweaked every setting in the phone properly (e.g. In Android itself, Settings -> Location -> three dots at upper right -> Scanning -> Wi-Fi scanning is OFF.) I just want it to shut off or turn on based on cell phone tower triangulation, and Wi-Fi Matic is not playing nice with DT2 Marshmallow like it did my other phones.
    I may need another Wi-Fi on/off app. You would think with a huge battery that Wi-Fi on all day isn't an issue, but it is. Let us not argue this base point of how the battery drain works. Fact is, there is battery drain and if I dig into my screen shots enough, I'd show you, but I am lazy. Just go with my track record of trying to be honest and helpful and trust me on this one, Wi-Fi is a drain.
    I just think the DT2 can be a clone of my DT1 with updated software and keep me happy. All I want is a good Wi-Fi on/off app, and I am perfectly happy. I love the phone. I have had no adjustment period at all. If we as a forum can fix my Wi-Fi issue with a good app, I will not do cartwheels as I do not want to end up in the ER, but, I will be very happy.
    06-19-2016 03:55 PM
  3. Zorro1's Avatar
    I'm a bit puzzled by the WiFi drain, too. WiFi should be the least draining compared to 4G. When I looked at my battery stats the other day on my three week old phone, I was shocked to see the steep drain just sitting around on WiFi!! I do figure a software update will fix it since they usually do...
    06-20-2016 11:23 AM
  4. Moo Cow's Avatar
    Doogald in PM told me to try a different app, but, he said what you did, essentially: a software update may be needed.
    06-20-2016 10:29 PM
  5. Moo Cow's Avatar
    WiFi is manually turned off by me. The green bar in battery settings is going straight through with no stoppage and that just shouldn't be. There is something wrong. I know they can't do anything but for laughs and giggles I may stop in at the VZW store and see what they say. I want to buy something anyway so it isn't a wasted trip.
    I am uninstalling the WiFi on/off app as a precaution, as well as a cache wipe (which will be fruitless). But, I doubt it does anything. At the end of my work day I bet the green bar stays strong.
    06-23-2016 10:21 AM
  6. Moo Cow's Avatar
    The green bar has stopped growing after uninstalling the app and wiping the cache -- and given a cache wipe took all of three seconds, there was no cache to wipe.
    One must now ponder if the WiFi Matic app caused the issue, or of any such app would. But i do want an app that uses cell tower triangulation to turn wifi on and off. It is a convenience for me.
    More research is needed on my part. I will follow up. I will first turn on WiFi at home tonight and turn it off before going to work tomorrow and see what happens. If the green bar doesn't exist, I can make a case the app was the issue. If it does, I will do a cache wipe again and see what happens. After all that I may try a new app.
    06-23-2016 11:24 AM
  7. doogald's Avatar
    I just read the FAQ for WiFi Matic - it's only been tested on Samsung phones through Jellybean 4.2, so it's maybe not surprising that it doesn't work right on Marshmallow.
    Again, I'd try Llama. It may have the same issue, but it was made for cell tower location based rules, for more than just WiFi, so it *may* work. It's an old app as well, though, so it may have the same issue on Marshmallow.
    06-23-2016 12:31 PM
  8. Moo Cow's Avatar
    Yeah apps seem to be early 2016 which is an issue. Marshmallow really came out later than those apps.
    First things first, what happens when I turn on WiFi at home to connect, then turn it off tomorrow morning to go to work? If it turns off, I can peg it to the app and try other apps.
    If the green bar doesn't stop, then we have a software issue. Then I will clear the cache and see what happens. Although clearing the cache every day would be an inconvenience.
    We will see. We here will come up with something once I get more research accomplished.
    06-23-2016 12:39 PM
  9. THEPRFCT10's Avatar
    I've posted about this a while back with no luck or help from anyone or anywhere. Extremely frustrating and I have no doubt it's draining my battery. For a 48 hour advertised battery, I'm lucky if I get 12!!!!!! Unacceptable.
    adayoff likes this.
    06-23-2016 01:46 PM
  10. Moo Cow's Avatar
    Well hopefully my research will help you. Not sure how much, as every situation can be unique, but, it may help you try something and experiment.
    Just keep checking the thread. At some point Friday I will have an update. At worst, during my noon ET lunch hour.
    06-23-2016 02:59 PM
  11. Moo Cow's Avatar
    And for proof... the vertical white line busting up the downhill green mountain (as I call it, sounds better than battery drain) is where I uninstalled the app and did a cache wipe and you can see after that, no WiFi solid green.
    Some of the downhill slope is legit usage but it leveled off even when not in use, whereas earlier when not in use it kept going down.
    06-23-2016 03:03 PM
  12. doogald's Avatar
    I seem to recall with the Turbo that somebody (maybe it was you, THEPRFCT10) learned that once WiFi was toggled off and then on, the battery status always showed it on even it was toggled off again until the phone was restarted. This was why I wondered if it was a Motorola bug (or something with Android.) I also wonder if it's something with the Moto app (for Assist purposes) - if it has WiFi permission, it holds the radio on even if you toggle off.
    06-23-2016 03:12 PM
  13. THEPRFCT10's Avatar
    I think so!
    06-23-2016 03:53 PM
  14. Moo Cow's Avatar
    Small sample size, I know. I am also convinced Facebook is a battery killer but I will be at a charger way before then anyway.
    But, with no WiFi on/off app installed, and WiFi turned off in every conceivable way in settings except having it on overnight from the pulldown menu on the home screen... When I woke up I turned WiFi off, drove 30 minutes to work, and waited another solid 30+ minutes, and the solid green bar of yesterday is gone and I have a projected 19 hours unless work is boring and I go crazy surfing.
    So I am convinced *my* issue was the app I had. Now, do I try another app and see what happens? I probably will. I am always up for experimenting.
    But basically, if WiFi is on, the battery will drain badly. If an OS would have auto on/off built in, that would be sweet. Until then, I will have to remember to turn it on/off manually.
    Not sure how much this helps anyone, but maybe it is a start.
    doogald likes this.
    06-24-2016 09:01 AM
  15. Zorro1's Avatar
    System update today. Now we see.
    07-01-2016 02:42 PM
  16. Moo Cow's Avatar
    I turned WiFi off at work, and well, nine hours later...
    07-08-2016 06:30 PM
  17. Zorro1's Avatar
    I leave my wifi on...and since the update, working as it should.
    07-11-2016 11:57 AM
  18. Moo Cow's Avatar
    I am bowing out of the research. I physically see it is off from any menu. But the battery bar is going across like it is on.
    If this is a bug, so be it. I may have found my auto on/off app so I am good there. But it is just weird the battery menu claims it is on. But I am still mid 90s in battery remaining after unplugging three hours ago and depending on how much I surf may significantly lower that, but I made it from 7:10a to 1:15a yesterday without a charge, albeit in the upper teens when I went to bed. Still, the battery had heavy use and did its job. I intentionally didn't charge in the car to see what would happen once I got home and truly was on WiFi.
    It is what it is I suppose. I am just nit picky at this point if it is a display bug and not a legitimate bug to worry about.
    07-12-2016 10:33 AM
  19. Moo Cow's Avatar
    I found a WiFi on-off app that works for Marshmallow.
    But WiFi, even when off in the pulldown menu from the top of the screen, shows as being active when I go to the battery status and click into it to see what is using my battery. Solid green bar.
    Battery drains will occur UNLESS I reboot on the way to work, at which WiFi is then shown as truly off and no drain or solid green bar. You wouldn't think this would be an issue on a big battery phone, yet it is.
    Therefore, it is bugged. I have done too much research on this -- inadvertently as I searched for a perfect WiFi on/off app -- to know it is.
    Not sure what else I can do.
    08-02-2016 09:45 AM
44 12
  1. Weatherbug cams Droid Turbo 2
    By AC Question in forum Motorola Droid Turbo 2
    Last Post: 09-25-2016, 02:37 PM
  2. why is my sms service acting wierd
    By rasmus1070 in forum OnePlus 2
    Last Post: 03-28-2016, 04:21 AM
  3. Why Alcatel One Touch Fierce XL is nowhere to be found in Alcatel site?
    By Smashfacemonster in forum Alcatel Android Phones
    Last Post: 03-23-2016, 03:33 PM
  4. Contact sync with Gmail is not working
    Last Post: 03-23-2016, 03:20 PM
