1. panteramatt's Avatar
    My turbo 2 just recently updated to the marshmallow OS. I noticed especially today that the battery is draining FAST! Usually I would get home from work with 40% left and it dies on me today. I didnt notice anything different when it updated except more emogies. The system version on my phone says its 23.31.24 kinzie is that right? How do I know the Doze is working?
    03-23-2016 06:56 PM
  2. Robert Beier's Avatar
    Have you done an FDR? Or cleared your cache, at least? Both recommended if you have issues after an OS upgrade.
    03-23-2016 07:14 PM
  3. panteramatt's Avatar
    Sorry I have no idea what that means. Im technologically ignorant haha,
    03-23-2016 07:16 PM
  4. Robert Beier's Avatar
    Factory data reset. Wipes your phone completely. Before that, though check the threads. There's a recent post about WiFi issues that could be related.
    03-23-2016 07:19 PM
  5. Ry's Avatar
    Curious... What are your expectations of Doze?
    Posted via the Android Central App on the Moto X Pure Edition
    03-23-2016 09:11 PM
  6. Golfdriver97's Avatar
    My first suggestion would be to clear cache in recovery. If that doesn't work, then a reset. How long ago was the update? It can take time for a new kernel to settle in.
    03-23-2016 09:20 PM
  7. panteramatt's Avatar
    Ok so the update never took. I see how this is extremely common and after searching and searching I downloaded verizon software assistant and got it to work. Now we will see how it works.
    03-24-2016 05:11 AM
  8. Hgouck's Avatar
    Your system version is incorrect for Marshmallow. It should be 24.14.11. You may have just updated the security patches and never got the second update to Marshmallow
    03-26-2016 07:48 AM
  1. What happened to photo cropping in Marshmallow 6.0.1
    Last Post: 01-28-2017, 09:37 AM
  2. Replies: 183
    Last Post: 04-14-2016, 01:05 PM
  3. i dropped my phone- help?
    Last Post: 03-23-2016, 06:50 PM
  4. I cant find default write disk in my phone.
    Last Post: 03-23-2016, 06:23 PM
  5. Replies: 1
    Last Post: 03-23-2016, 05:41 PM
