1. Kaguar77's Avatar
    In my accessibility menu, there's an option System Monitor that is on and I never enabled it and ever since I keep getting random pop-ups at random times. If I try clicking it, it takes me back to the main settings menu. It's very frustrating and I want to disable it because I have Kaspersky installed for anti-virus but my phone isn't letting me.
    Just now while typing a pop-up for a game showed and it redirected me to the app store. It's very annoying and I don't know what it is. I ran a scan on my phone thinking it's a virus and it doesn't show up as anything being infected.
    Pop-up happened when writing this and this time it wouldn't go away. I went to post a picture of it with the phone rotated because it allowed me to see half the screen and I clicked the screenshot and instead it posted a picture of a cat..... OK.....
    03-26-2016 06:29 AM
  2. Kaguar77's Avatar
    This is what I wanted to post
    03-26-2016 06:36 AM
  3. Kaguar77's Avatar
    And this
    03-26-2016 06:36 AM
  4. Kaguar77's Avatar
    And finally
    03-26-2016 06:37 AM
  5. N4Newbie's Avatar
    Go to Settings -> Apps and see if System Monitor is in the list. If it is, tap on it and then tap the Uninstall button.
    Let us know if that works.
    03-26-2016 06:45 AM
  6. Kaguar77's Avatar
    That was one of the first things I did, sorry for not mentioning that lol. It's not listed as an app or anything. And the pop-ups are always advertising games and apps. And is random and will do it even if the screen isn't awake.
    doogald likes this.
    03-26-2016 10:47 AM
  7. Kaguar77's Avatar
    I think I'm gonna have to do a factory reset at this point. My antivirus isn't finding it as a virus or anything.
    03-26-2016 10:48 AM
  8. copywrite's Avatar
    Have you checked your running services in developer settings for anything running that you don't recognize? Check your app list for anything as well? Boot in safe mode? I would try unistalling your kaspersky also, there is really no need for it and it could possibly be the cause. You should be able to fix this without a FDR.
    doogald likes this.
    03-26-2016 01:14 PM
  9. jonstrong's Avatar
    I would also go into Settings / Security / Device Administrators, and see if anything is registered in there that you don't recognize.
    03-26-2016 01:34 PM
  1. Replies: 1
    Last Post: 03-28-2016, 07:34 AM
  2. Replies: 0
    Last Post: 03-26-2016, 02:16 AM
  3. Replies: 1
    Last Post: 03-25-2016, 09:44 PM
  4. Note 3 file system has some kind of corruption
    By evereddie in forum Samsung Galaxy Note 3
    Last Post: 03-25-2016, 05:36 PM
  5. Accidentlly deleted all system files. NEED HELP!!!
    By Elvinas in forum Moto X Pure Edition
    Last Post: 03-25-2016, 01:02 PM
