1. THEPRFCT10's Avatar
    Ringtones and notifications especially when on full volume are about half as loud as what they used to be. Frustrating.
    03-31-2016 09:14 PM
  2. teeitupmo#WN's Avatar
    Did you factory reset the device? I upgraded earlier today, after 6.0 installed, I immediately reset phone. No audio issues. Was streaming music on way home with no difference in audio levels.
    Have you noticed any other issues?
    03-31-2016 09:20 PM
  3. Robert Beier's Avatar
    I haven't had any issues with volume. Works the same as with Lollipop.
    03-31-2016 09:22 PM
  4. jonstrong's Avatar
    I've upgraded 3 turbo 2's to Marshmallow - no audio issues at all, volumes don't seem any different. I'm assuming that you have tried expanding the volume drop down, so you can see the separate settings for ringtone, media and alarm volume?
    03-31-2016 09:32 PM
  5. doogald's Avatar
    See this thread. Sound Issues with Marshmallow?
    http://forums.androidcentral.com/sho...d.php?t=653207
    Well, you posted in it, so I assume you saw it. Do you have a text message app (are you still using textra?) with the notification setting to do a pop up when you get a message? If you turn that off, does that fix the problem?
    03-31-2016 09:37 PM
  6. THEPRFCT10's Avatar
    Yes I have.
    04-01-2016 12:44 AM
  7. THEPRFCT10's Avatar
    I do use Textra, hmmmmm. I'll have to look at that thanks!
    04-01-2016 12:44 AM
  8. rdjr74's Avatar
    I'm experiencing the opposite. My volume is now much better, louder. Before the update it was very low.
    04-01-2016 12:03 PM
  9. THEPRFCT10's Avatar
    Weird.
    04-01-2016 02:24 PM
  10. jonstrong's Avatar
    Actually...I'm using Textra too, and was before the Marshmallow upgrade as well as now (after). Doesn't seem to have any effect on volume, pro or con.
    04-01-2016 09:19 PM
  11. revtech's Avatar
    Never mind, deleted post . . . .
    Actually I should put this out there if it helps someone, even though it's very embarrassing for me - I found out that my low volume problem was due to the act that I still had the factory screen protector on and it doesn't have cut-outs for the speaker (facepalm). . . .
    Kinda like the old "is it plugged in" joke . . .
    Laura Knotek likes this.
    04-02-2016 12:55 PM
  12. Laura Knotek's Avatar
    Don't feel bad. All of us do things like that sometimes. 😊
    04-02-2016 03:27 PM
  1. Anyone in the Long Beach area know how to flash?
    By dirtyjudo in forum Google Nexus 9
    Last Post: 06-04-2016, 11:08 AM
  2. Replies: 1
    Last Post: 04-05-2016, 07:05 AM
  3. mm 6.0.1 update,country's and experience ?
    By manus31 in forum Moto G (2015)
    Last Post: 04-01-2016, 09:59 AM
  4. Replies: 1
    Last Post: 04-01-2016, 05:25 AM
  5. Dropped HTC Desire in Water...
    Last Post: 03-31-2016, 09:18 PM
