1. AC Question's Avatar
    In order words, I would like to move a particular photo to a different place with the folder. I thought I could do it with the phone connected to the computer, but I can't seem to figure it out. It should the picture on the computer in the place I want it but it doesn't change on the phone.
    04-03-2016 06:32 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The stock Gallery will simply display the photo files in your phone's directories in a set order (not sure if it's in time/date order or image filename alphabetical order). Stock gallery apps or the Google Photos app won't let you reorder the photos in a specific way--you'd have to try different 3rd party gallery apps.
    04-03-2016 09:24 PM
  3. tlacour's Avatar
    I use QuickPic for my gallery app. It allows you to sort pics by date taken, size, date added to phone, and file name, and maybe other ways.
    Unfortunately, I don't think you can move pics around in any order. Every app that I've seen sorts pics by some sort of criteria automatically. If you're trying to get a pic to always be first or last, you can rename the pic in such a way that a sort by file name will put it first or last. You can also put specific pics in a separate folder for quicker access.
    T
    04-04-2016 11:35 AM
  1. How to stop updates/notifications from Verizon on S7
    By Texan2drvr in forum Samsung Galaxy S7 Rooting, ROMs, & Hacks
    Last Post: 04-04-2016, 05:35 PM
  2. anyone trade-in a galaxy s6 for an S7 and get the $300?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 04-04-2016, 04:43 AM
  3. Need help transferring all my old texts from my old droid maxx to this phone
    By ScofieldReturns in forum Samsung Galaxy S7 edge
    Last Post: 04-03-2016, 10:08 PM
  4. Why is my BLU phone using data when turned off?
    By AC Question in forum Blu Android Phones
    Last Post: 04-03-2016, 09:52 PM
  5. Replies: 1
    Last Post: 04-03-2016, 07:46 PM
