1. kognak51's Avatar
    I recently purchased a new Droid Turbo 2 phone this year to replace my galaxy 5 . I used a 128 gb sd memory card with my galaxy for mostly music. When I tried to switch over I had to reformat the sd card to work with my Turbo. I was able complete the process of copying data to laptop -> reformatting sd card (it gives you the option to format as portable vs internal storage, i chose storage which i am guessing now was my first mistake) -> copying back to sd card with no problem. Today, I absent-mindedly tried to switch my sd card to my less cumbersome mp3 player so I could listen to my music while I ran( something I did regularly with my galaxy). Obviously, it didn't work (due to the conversion process) so I figured I would put it back in the droid and just copy maybe an hour or two worth of music to one of my smaller sd cards. When I tried to reinsert the 128 gb card in the turbo it said the card was corrupted. I have tried fix it using my laptop but it just gives me the option to reformat and doesn't recognize any data being present at all. I tried using chkdisk but as I stated before it doesn't recognize it as being a usable drive. I numerous pictures, videos, and literally a library of music on this card if anyone knows anything that could help please let me know.
    01-29-2017 10:08 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Sorry, but you may be out of luck. You're right -- formatting the card as internal storage was a problem, because that encrypts the card. After the card got corrupted, it's doubtful that you can recover the data, even with one of those data recovery programs, because of the encryption.
    01-29-2017 10:33 PM
  3. Pollster's Avatar
    I would try the usual flailing. Shut the phone down and start back up without the card, then shut down and start back up with the card.
    01-30-2017 01:09 PM
  1. Having a problem with my Note 5, when on speaker phone, need help
    By anderdea in forum Samsung Galaxy Note 5
    Last Post: 02-05-2017, 01:17 PM
  2. Facebook app help.
    By Lucy Davies in forum Moto G
    Last Post: 01-31-2017, 07:07 PM
  3. HELP pls Phone Bricked Can't flash files in Odin
    By ornir in forum Ask a Question
    Last Post: 01-29-2017, 03:36 PM
  4. Galaxy S4 gallery and sd card duplicating
    Last Post: 01-29-2017, 09:42 AM
  5. My network card is missing
    Last Post: 01-29-2017, 08:31 AM
