1. daronmal's Avatar
    My phone, within the past few days, has dumbed down or something, the motion sensor no longer works at all, and the vibration when I get a text or call doesn't work anymore either. Should I reset the phone? I really don't want to, but I will if I have to.
    02-22-2017 09:55 AM
  2. B. Diddy's Avatar
    See if it happens in Safe Mode first: https://motorola-global-portal.custh...p/30,6720,9583
    02-23-2017 03:41 AM
  3. Soundtallica's Avatar
    It's impossible to say for sure what's wrong with your phone. You should only go through a factory reset if you've tried absolutely everything else.
    I will say that the vibration motor crapped out on my Turbo 2 when I owned it though. I had Verizon warranty replace it for me.
    02-27-2017 03:33 PM
  1. why media files are not downloading properly?
    Last Post: 02-22-2017, 06:36 PM
  2. Would You Buy a Not 7?
    By cogic740 in forum Samsung Galaxy Note 5
    Last Post: 02-22-2017, 06:17 PM
  3. Why my home and notification bar is not working?
    Last Post: 02-22-2017, 11:22 AM
  4. android settings app is not working?
    Last Post: 02-22-2017, 04:56 AM
  5. Replies: 0
    Last Post: 02-22-2017, 02:07 AM
